What octane rating of gas is recommend for the LT1?
Old Nov 15, 2007 | 07:14 PM
zo6vette's Avatar
Just wondering what octane rating is recommed for a stock LT1? Does anyone here use 87 octane?
Old Nov 15, 2007 | 07:26 PM
mrz28 73/97's Avatar
I believe my car has a " use premium fuel only" sticker but that's all I use anyway.
Old Nov 15, 2007 | 07:30 PM
drptop70ss's Avatar
I have run nothing but 87 in mine since I got it, runs fine with it, but I drive it like a normal car and do not beat on it.
Old Nov 15, 2007 | 07:40 PM
n2ceptor's Avatar
91+ is recommended......
Old Nov 15, 2007 | 07:41 PM
TA'95's Avatar
Octane
Stock LT1's should run on 91 or higher octane for best performance. 89 or lower can be used but will have a decrease in accelaration. Thats what it states in my manual for my 95 Trans Am. Hope this helped.
SS RRR's Avatar
I don't believe so. Those stickers were only on the LT4 setups.
Any gas can be used in the LT1 due to the nature of the knock sensor/module setup being sensitive enough to pick up a fly's fart at fourty paces. Won't hurt anything but performance.
Old Nov 15, 2007 | 08:55 PM
Lt1son's Avatar
93 All Day
Old Nov 15, 2007 | 09:01 PM
NemesisLT1's Avatar
in my 94 owners manual im pressure sure it suggest 89 or higher... i use mid-grade all the time which is 89 octane... i used 87 one time and it felt sluggish, ive also used 91 and didnt notice any difference....
Old Nov 15, 2007 | 10:31 PM
Your 94 Owner's Manual recommends 91-octane.
Use premium unleaded gasoline rated at 91 octane or higher. You may use middle grade or regular unleaded gasolines, but your vehicle may not accelerate as well...... Be sure the posted octane for premium is at least 91 (at least 89 for middle grade and 87 for regular). If the octane is less than 87, you may get a heavy knocking noise when you drive. It it's bad enough, it can damage your engine.
Old Nov 15, 2007 | 10:51 PM
SS RRR's Avatar
That raises the question is 91 necessary for those who reside in high elevation areas? Colorado for example has 85 87 and 91. In the mountains I believe the highest level is either 85 or 87.
Old Nov 15, 2007 | 10:58 PM
bombebomb's Avatar
I use 93.5(high test here), if I want to skimp on the gas ill buy a honda. Come to think of it, I have nearly 3/4 of a tank of 93.5 rotting in my driveway, better do something with it.
Old Nov 15, 2007 | 11:03 PM
JoeliusZ28's Avatar
i use 94 ultra sunoco whenever possible.
Lowest ive run is 92... i didnt feel a performance difference but my track results showed one believe it or not. well i shouldnt say that, it was one of a couple factors giving me bad results.
previous owner said my car spark knocked on 89 and said he would never try it again.
Old Nov 15, 2007 | 11:50 PM
Octane requirement drops as elevation increases. It is also reduced with lower intake air temps, and lower coolant temps.
Old Nov 16, 2007 | 12:22 AM
SS RRR's Avatar
http://www.koaa.com/news/view.asp?ID=251
interesting read
Old Nov 16, 2007 | 12:49 AM
speed_demon24's Avatar
You'll lose any money you gained by filling up with the lower octane gas by the decrease in gas millage from it pulling timing.
