what is the normal idle speed for a 94 lt1?
i have a 94 z28 that is bone stock, engine wise. im just wondering what the normal idle speed should be b/c mine seems a bit high. once it has warmed up and settles, it stays at 1000 rpm and never falls below that. is this normal? if not, what can i do to rectify the situation?
thanks,
Mike.
thanks,
Mike.
Don't forget the tach is probably off some. Mine on a cold start sits at 1500 for a bit, settles to 1000, then 800 when warm, then 600 in drive when warm. The stock tach is off a few hundred rpms, the only way to get a for sure reading is a different tach or a computer scanner.
The best thing to do would be to put a scanner on it.
First, check the RPM reading on the scanner.... that will eliminate the inaccuracy of the stock tach. Mine always showed 900rpm on the tach, and 800rpm on the scanner.
Then check the IAC "counts".... should be in the range of 20-40 counts. If the IAC counts are low, it could indicate the engine is getting air from another source, like a vacuum leak.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jb4xx
Feb 2, 2015 10:00 PM
Alex Barnes
Jan 24, 2015 10:21 PM
