What next? need help
Old Nov 3, 2003 | 09:26 AM
jer4251's Avatar
I wasn't too happy this summer with my cars performance. I need some input on what i should do to better my times.
With all the mods i have listed below i ran a best time of 13.952@ 100.63 with a 2.2 60".
I've done all the free mods. i have jet hot longtubes, offroad y-pipe with a single bullet dump. lowered 2" ebiach sportlines. spyro pro's 8mm wires. 180 stat, T-byrne porten MAF with no screen. !EGR, !AIR, !CAGS, !CATS, TB bypass.17x9.5" wheels with kumho's. 6-speed. real SS. anything i might have forgotten should be listed in my SIG.
I have not programmed the PCM yet, will that help?
i was thinking about 17x11" Zr1's with DR's
RR's
LCA relocations brackets(or some other susp. mods)
Aftermarket air filter( part numbers?)
i really dont want to mess with internals yet. like cam's but i will in the future.
shouldn't stock SS's be running low 14's high 13's?
is there something wrong with my car?
Old Nov 3, 2003 | 10:11 AM
S.J.S.'s Avatar
Hell ya you should be running faster. My 97Z bone stock did a 14.1 with 1k on it. Well it depends on your altitude your racing at.
I noticed you were talking about tires and LCA's. You never mentioned if traction was a problem. If it is a problem, then theres your answer. If not I wouldn't worry too much about the programming as you dont have enough mods on there to make a difference.
