What next? need help
I wasn't too happy this summer with my cars performance. I need some input on what i should do to better my times.
With all the mods i have listed below i ran a best time of 13.952@ 100.63 with a 2.2 60".
I've done all the free mods. i have jet hot longtubes, offroad y-pipe with a single bullet dump. lowered 2" ebiach sportlines. spyro pro's 8mm wires. 180 stat, T-byrne porten MAF with no screen. !EGR, !AIR, !CAGS, !CATS, TB bypass.17x9.5" wheels with kumho's. 6-speed. real SS. anything i might have forgotten should be listed in my SIG.
I have not programmed the PCM yet, will that help?
i was thinking about 17x11" Zr1's with DR's
RR's
LCA relocations brackets(or some other susp. mods)
Aftermarket air filter( part numbers?)
i really dont want to mess with internals yet. like cam's but i will in the future.
shouldn't stock SS's be running low 14's high 13's?
is there something wrong with my car?
RR's
Hell ya you should be running faster. My 97Z bone stock did a 14.1 with 1k on it. Well it depends on your altitude your racing at.
I noticed you were talking about tires and LCA's. You never mentioned if traction was a problem. If it is a problem, then theres your answer. If not I wouldn't worry too much about the programming as you dont have enough mods on there to make a difference.
