What mods to do with the engine pulled... ? ?
Old Apr 7, 2003 | 04:22 PM
pu12en12g's Avatar
What mods are good to do with the engine pulled ?
So far, here is my list:
- Tranny Rebuild (with no engine, seems like a good time to rebuild this as well)
- AC delete / Radiator Relocate
- Alternator relocate
- Window washer fluid relocate, custom Ram Air / Z06 CAI fabrication.
- TPIS Coated headers (if they come coated)
- New CAM, undecided on which one I want to go with, I need the best cam designed for Supercharged (but Daily Driven) applications, so I need some ideas here.
- Powdercoated / Anodized Plenum, TB, and every metal engine component. (I get hooked up on powdercoating per run, so the more things I can do at once, the better..)
- New Spark Plugs, OTVC wires
- Engine dyno ?
- Port / Polish
- Fully repainted and polished engine bay
What are some good things to add to this list while the engine is out ?
I have over 100,000 miles, so what engine components should (or wisely could) be replaced at this time ? ?
Old Apr 7, 2003 | 06:16 PM
95m6's Avatar
I would def. think about new opti and electric water pump. !air and !egr delete too if emissions aren't a problem, this would clean up the engine bay nicely since you're powder coating items and repainting. And lastly, what about a new alternator? They have chrome ones out and anything over stock would definatly be a plus.
Old Apr 7, 2003 | 08:43 PM
pu12en12g's Avatar
That would be cool.. even if the alternator is relocated..
Old Apr 8, 2003 | 08:14 AM
pu12en12g's Avatar
Do any of you have a system for keeping track of what part or bracket goes where in the engine bay ?
All the brackets and attachments will come back powdercoated so simply labelling them isn't really a option...
Any thoughts ?
Old Apr 8, 2003 | 08:28 AM
MeanGreen97Z's Avatar
Tubular K member and a arms.
Old Apr 8, 2003 | 08:34 AM
pu12en12g's Avatar
For weight reduction only or is there another reason ?
Just curious.
Old Apr 8, 2003 | 04:03 PM
pu12en12g's Avatar
Ok here is the updated list:
- Window washer fluid relocate, custom Z06 CAI fabrication.
- TPIS headers (if they come coated)
- New CAM, undecided on which one I want to go with, I need the best cam designed for Supercharged Daily Driven applications.
- Change Spark Plugs, OTVC wires
- Engine dyno ?
- Port / Polish
- Fully repainted engine bay
- Notorious intake leak fix
- New motor mount (?)
- TPIS !EGR plates
- LT4 heavy duty timing chain
- New U-joints (since the car will be O.O.C.)
- Powdercoat my coilovers
- New shocks/Struts (probably Bilstein) powdercoated
- Suspension rebuild (especially new ball joints, since I am getting some strange handling characteristics since I hit the deer) [b]Possibly from LS1 . .good idea ?
- Front LS1 brake upgrade (calipers powdercoated with engine/suspension components)
- Dynamat entire car (or equivalent) since the car will be O.O.C.
- Finish show interior
- Get rid of the MAF
- Relocate battery to the trunk
cheapchevy
Apr 8, 2015 08:48 PM
alex5366
Mar 8, 2015 11:32 AM
k1996z28
Jan 21, 2015 07:22 AM
