fog lamps
fog lamps
hello im new to the board. my name is frank. i just bought a 95 z28 and my first question is how do you change the fog light bulbs. because for some reason i am having a hard time getting to them also how do you take off the mounting bracket? i have to change one of the cracked lenses.
thanks frank
thanks frank
I had the same problem on my 94, unfortunatly I dismantled the whole air dam and lower part of the fron end before finding that you can just pop out the plastic pins on the side of the lamps to change the bulb. Should work for the lens too.
Someone else might be able to link you to a site with pictures.
Here's a link, hope it helps.http://www.bfranker.badz28.com/fbody/fogs.htm
Aug 17, 2015 09:50 AM
