What minor mods would constitute a retune?
Old Nov 15, 2006 | 10:41 AM
BlackbirdWS6's Avatar
Hey Guys,
I'm looking at porting the entrance to my LT1 intake manifold to take advantage of the 58mm tb. I've had the car dyno tuned and all that, but would doing this consitute needing another tune?
-Brian
Old Nov 15, 2006 | 10:51 AM
reamo04's Avatar
i don't think it would, but don't quote me on this. All it is doing is allowing more air to enter the car. no different than adding a CAI.
Old Nov 15, 2006 | 12:10 PM
Sweetred95ta's Avatar
You'll be fine. The BLM's should correct for it wanting to run a little leaner.
Old Nov 15, 2006 | 12:17 PM
godspeed1976's Avatar
While a tune might make a little difference, I don't think it is enough to justify doing it.
Old Nov 15, 2006 | 12:20 PM
On an A4, you might have some issues with shift points that require reprogramming. With an M6, it shouldn't be a problem.
The BLM's don't have to "correct for it wanting to run a little leaner".... if it actually flows more air, the MAF sensor will measure the added air flow, and the PCM will add the correct amount of fuel.
Might want to add tranny type to you signature.
Old Nov 15, 2006 | 12:28 PM
This is where my head was at but I just wanted to make sure. Thanks guys and the sig is fixed.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
DelSoto
Sep 19, 2015 05:31 AM
tommalcolm
Sep 11, 2015 03:39 PM
CARiD
Jul 7, 2015 08:19 AM
