What is ment by bolt on?
Old Feb 4, 2003 | 08:29 PM
Cerwin Vega Fan's Avatar
Question What is ment by bolt on?
Like what makes a bolt on a bolt on? Could you name some bolt on examples?
Old Feb 4, 2003 | 08:32 PM
AZ2ENVY's Avatar
Any modification that doesnt tear into or replaces the top or bottom end of the motor ie; pistons,crank,rods,etc.
A few examples are headers, roller rockers, gears,cai,etc.
Hope this helps
Old Feb 4, 2003 | 08:36 PM
Javier97Z28's Avatar
Moderator
cold air intakes
mufflers
catbacks
headers
torque converters
suspension components
drag radials/slicks
igntion components (MSD blaster boxes, coils...)
roller rockers I guess, alot of people call them bolts ons, my bolt on car got into the 12's w/o 'em, so I'm happy.
Old Feb 4, 2003 | 09:20 PM
drop top steve's Avatar
Re: What is ment by bolt on?
At one time it was any thing that did not touch oil, but now a lot of "bolt-on" cars are running roller rockers. Not a bolt on imho.
Old Feb 5, 2003 | 12:00 AM
ky94transam's Avatar
Would not consider roller rockers (have to remove valve covers),gears,Or a torque converter a bolt on.{any thing that bolts on the the outside of motor or drivetrain is considered bolt on} Just my opp.
Old Feb 5, 2003 | 12:15 AM
Fear The Z's Avatar
If you think about it, its ALL bolt ons
Old Feb 5, 2003 | 12:24 AM
But do you have to take something off too get to the part you are bolting on.
Old Feb 5, 2003 | 12:28 AM
Moderator
if a torque converter isn't a bolt on.. then neither is upgrading to an aftermarket clutch in an M6 for more holding power.... therefore making any M6 w/ an aftermarket clutch not a bolt on car anymore.. can't go w/ that reasoning
the whole point is so that the car can launch harder off the line..
Old Feb 5, 2003 | 12:33 AM
what does that have too do about a bolt on................................................ .................I I can put a narrowed rear end with larger tires on...does that make it a bolt on?
Old Feb 5, 2003 | 01:35 AM
Moderator
sure but that wouldn't make much sense on a car that couldn't make use of that rear b/c the motor only had bolt ons.. are you getting what I'm saying? oh well no biggie i don't care
Old Feb 5, 2003 | 08:07 AM
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
one wicked element
Aug 18, 2002 07:53 PM
