What M6 tranny fluid to use?
Old Jun 5, 2003 | 12:00 PM
  #16
Laymaster's Avatar
Originally posted by Dmx4ever3
I USED RP SCYROMAX AND NOW IM HAVING PROBLEMS GOING INTO REVESE LIKE I HAVE TO FORCE IT IN AND WHEN I START TO SHIFT SOMETIMES IT GRIND AND WHEN I JUST DRIVE THE CAR SOMETIME I HAVE NO PROBLEMS AT ALL I PUT A NEW CENTERFORCE DF CLUTCH AND 4.10 GEARS WHAT SHOULD I DO PUT THE GM STUFF IN HONDA??? WHATS WILL FIX THIS I NEED HELP FROM SOME ONE ON THE BOARD
When I changed my clutch I put in a McLeod dual performance clutch. Since then it hasn't been as easy to shift out of first into neutral (when sitting still) sometimes, or going into gear sometimes...reverse qualifies under this category. For some reason, the clutch doesn't disengage fully (sometimes).... You may have the same problem. Try adding DOT-3 brake fluid to your clutch master cylinder.
Old Jun 5, 2003 | 12:55 PM
  #17
WOT's Avatar
WOT
I use Pennzoil Dex3 and change once a year. I used to use Mobil 1 ATF but it shifted funny when cold. I cannot tell a difference between the two when it comes to my t56.
Old Jun 5, 2003 | 03:13 PM
  #18
BigRich's Avatar
I really doubt that Honda ATF is better than
the 3.8 quarts of Redline D4 ATF that i just put into my M6
http://www.redlineoil.com/products.htm
very smooth
Old Jun 5, 2003 | 03:38 PM
  #19
jasons93z's Avatar
Is maxlife any good in our cars?
Old Jun 5, 2003 | 03:57 PM
  #20
rpm4lalo's Avatar
Mobil 1 ATF.
No problems.
Old Jun 5, 2003 | 05:48 PM
  #21
cals400ex's Avatar
i run maxlife in mine. it is definately smoother than the other stuff that was in there. however, it was probally old.
Old Jun 6, 2003 | 12:08 AM
  #22
jasons93z's Avatar
well, i guess i will use maxlife. Its 4qts correct?
Old Jun 6, 2003 | 02:46 AM
  #23
Carlos01SS's Avatar
I use Honda ATF, the BW 6-speeds like the stuff apparently. My shifting is smoother since I switched. Two Seattle mechanics, Z28.com members who do their work in Washington, and another friend mechanic of mine in L.A area all told me that the Honda ATF works REAL GOOD with our 6-speeds.
My tranny's happy, me happy!
Old Jun 6, 2003 | 03:17 AM
  #24
Dmx4ever3's Avatar
SO WHAT FLUID WILL MAKE ME SHIFT THE SMOOTHEST? AND FIX MY PROBLEM CAUSE THE DEALER SAYS TO PUT THE GM STUFF BACK IN . I USED RP SCYROMAX
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
