what is line boring??
Old Apr 19, 2005 | 05:34 PM
TURBOnCAMARO's Avatar
i am getting splayed main caps for my motor but the guy with the main caps said i have to line bore?? any help
thanks
Old Apr 19, 2005 | 05:36 PM
Dave89IROC's Avatar
Re: what is line boring??
it is boring out the main bearing journals, yes, you need to line bore with splayed caps
Old Apr 19, 2005 | 05:37 PM
Mindgame's Avatar
Yep, the caps aren't to bore size right out of the box. Your machinist will need to bolt them to spec and bore the main bore to size. That's really about all you need to know.
Typical machine work for any performance oriented engine build shop.
edit: Dave was quicker on the draw..... must be getting old.
-Mindgame
Old Apr 19, 2005 | 05:50 PM
Dave89IROC's Avatar
-Mindgame
but you explained it better
Old Apr 19, 2005 | 06:40 PM
lovescamaros25's Avatar
actually I think its called align bored.
Old Apr 19, 2005 | 08:55 PM
OldSStroker's Avatar
or align boring. It's followed by align honing or "line honing" to get the final size.
Choose a good shop which does it regularly and successfully. Steel main caps are sometimes very tough to machine (compared to cast iron) and the main bores don't always end up better than they were originally. You are trying to remove the minimum amount of material from the block and sometimes almost an 1/8 " from the new caps. It's not fun to do correctly.
Old Apr 20, 2005 | 04:02 AM
rskrause's Avatar
Moderator
And if it's not done correctly
Rich
Old Apr 20, 2005 | 02:27 PM
SStrokerAce's Avatar
Very true!
Old Apr 20, 2005 | 08:11 PM
94zgreenmachine's Avatar
Rich
I just gone done with this problem myself. One of the caps wasn't set all the way down in the register. I got better caps out of the deal and the machine shop was "nice" enough not to charge for the align boring the second time. Like I screwed it up in the first place.
Actually, I am waiting for Brett(went thru Lloyd) to design my cam and get it out to me. Warm weathers comin and the cars ready to go!!! Well, sort of....
HectorM52
Jul 30, 2017 11:46 AM
beltrunner
Apr 15, 2015 01:10 AM
carl.froehlich
Mar 13, 2015 12:38 AM
91Bird305
Aug 5, 2002 01:39 PM
