What lifters, rockers, push rods, etc
Old Feb 2, 2004 | 01:07 PM
zachattack45's Avatar
Ok i have decided to go with the AFR CNC ported heads for my LT1 stroker engine. Now i just need to know what everyone recommends for roller rockers, lifters, pushrods, etc. Let me know
Old Feb 2, 2004 | 03:43 PM
96ta(nick)'s Avatar
Comp Pro Magnum NSA rockers
Comp Hi-Tech pushrods
Comp Guidplates
Comp lifters (forgot which ones i went with)
that is the setup i went with...
Old Feb 2, 2004 | 03:46 PM
doesnt the afr heads have guideplates ?
Old Feb 2, 2004 | 04:07 PM
ibanez6rg's Avatar
GM guide plates, Pro Mags, Comp R lifters!
Old Feb 2, 2004 | 05:12 PM
AsianSensation's Avatar
Yes, they do come with guide plates.
Old Feb 2, 2004 | 07:10 PM
rskrause's Avatar
Moderator
Assuming an HR setup.
Heads come with the correct guideplates
I think the heads will come with rocker studs, if not, ARP
Comp Pro-Magnum hydraulic lifters
Comp Magnum pushrods (save a few $$$, the Hi-Tech line is clearly not warranted)
Comp Pro-Magnum rockers
Rich Krause
Old Feb 2, 2004 | 07:23 PM
FacelessZ's Avatar
Just get a set of replacement stock lifters...you don't need the 'R' lifters...
NSA as far as rockers go with GM guideplates...
Comp hardened pushrods...
oldschool
Feb 9, 2016 09:21 PM
KamikaZ28
May 28, 2015 12:45 AM
nikolt1
Feb 27, 2015 09:10 PM
alphaauto
Jan 23, 2015 07:42 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
