High RPM Miss
Old Feb 1, 2004 | 10:19 PM
Robs97Z28's Avatar
High RPM Miss
Has any one had problem with high rpms miss? It starts around 5000. replaced plugs, wires, opti, tried adjusting fuel pressure, and new coil. Any suggestion?
Old Feb 1, 2004 | 10:39 PM
cridom's Avatar
intake elbow?leak
Old Feb 1, 2004 | 10:49 PM
Robs97Z28's Avatar
new 1LE..more than likely not. it is only a few weks old.
ledfootz28's Avatar
try o2 sensors.could be other sensors like the map sensor
Old Feb 1, 2004 | 11:10 PM
Robs97Z28's Avatar
replaced both preccat O2s with bosch units and no change.
Old Feb 1, 2004 | 11:20 PM
jasons93z's Avatar
Have you made sure that none of the new wires are burnt because of not placing them in the right location.
Old Feb 1, 2004 | 11:33 PM
Robs97Z28's Avatar
put them back in the stock location. But, wouldn't a burnt wire would set a code?
Old Feb 1, 2004 | 11:35 PM
jasons93z's Avatar
Nope, to me, its sounds like a coil problem. So.....did you change the coil wire also?
Old Feb 2, 2004 | 12:06 AM
Robs97Z28's Avatar
new coil msd...2nd set of wires,,,first set was msd and second set are tpis. car runs better with tpis wires rised the miss high up in the rpm band. it was starting from 4500, but I have made many other changes it has move above 5 grand. I'm beginning to think it is the opticrap.
Old Feb 2, 2004 | 06:58 PM
$hawn's Avatar
Maybe partal clogged fuel filter and/or injectors, that or valve springs getting tired?
Old Feb 2, 2004 | 07:11 PM
Robs97Z28's Avatar
fuek filter is new, it is the 3rd one since the new fuel pump.
I don't think it is valve springs because early mornings it is less likely to miss. there times when it runs almost normal (no miss) early in the morning. my thinking is the cooler dense air, which is easier to burn.
this is what leads me to ignition or air/fuel ratio. Thinking of running it on the dyno.
Old Feb 2, 2004 | 07:14 PM
tagz's Avatar
Not sure if that would cuase your problem or not, but be sure that the bottom of the intake elbow is on. Mine tends to get folded up/in some times.
Old Feb 2, 2004 | 07:24 PM
Kain's Avatar
I had about the same, turned out to be coil and coil to opti wire and....
my valve springs were way too weak for my cam. Maybe your valve springs are getting weak from age?
Old Feb 2, 2004 | 07:29 PM
Robs97Z28's Avatar
I'll check, thanx everyone for your help!! Back when it was mainly stock, I still had this same problem. I have been trying find what I did to start this dilemma. It has been driving me crazy.
lt1matt
Mar 21, 2015 07:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
1996LT1Z28
Mar 8, 2015 08:16 PM
DetroitZ28
Feb 13, 2015 07:33 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
