what lifter preload works best with comp 850's?
Old May 28, 2006 | 03:50 PM
firebirdStud's Avatar
Exclamation what lifter preload works best with comp 850's?
I just redid my motor, and I set the valve lash at 1/4 turn past zero lash. I have a custom cam, chrome molly pushrods, comp pro mags, beehive springs, and comp 850 lifters. Its a daily driver, prolly see no more than 6500 rpms? I just want to make sure 1/4 turn isn't too loose to destroy the lifter cup retainers like the comp "r's" seem to do.
Cody
Old May 28, 2006 | 04:11 PM
1racerdude's Avatar
Re: what lifter preload works best with comp 850's?
1/4 is fine. Make sure the poly locks are TIGHT.
Old May 29, 2006 | 01:07 AM
oh yeah, I reefed on those pretty good. Prolly about two grunts worth.
Old May 29, 2006 | 01:16 AM
1racerdude's Avatar
Two HEAVY grunts is the torque spect,so ya will be OK.
Old May 29, 2006 | 09:44 AM
sweet!
Old May 29, 2006 | 10:21 AM
turbo_Z's Avatar
I tighten mine to 1/8 past and lock them down. Then with the locks as tight as you can get them with a hex wrench... take the nut another 1/16 turn or so to be absolutely certain.
Old Jun 1, 2006 | 09:18 PM
cehan's Avatar
The instructions that came with my original Hot Cam kit years ago said to torque the polylocks to 20 ft lbs. So that's what I've been using ever since, never had one come loose yet.
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
alphaauto
Jan 23, 2015 07:42 AM
siguy
Nov 27, 2014 10:07 AM
