What kinda vacumn shoud we be getting?
Old May 24, 2003 | 04:46 PM
94FlamdS10Blazr's Avatar
Ok im having what I think to be a bad intake gasket and high idle, hard starting when hot and a bad missing at 180-200 when the closed loop kicks in. I hooked up a vac gauge at the line where the egr came from being as I dont have one now and im getting around 18-20 at idle and 0 when I rev it! Does that sound right? I dont have a vac canister cuz I think mine is dead , cracked or something like that.
Old May 24, 2003 | 04:50 PM
19-20"Hg vacuum at idle is normal with a stock cam. 0-2"Hg is normal when you have the throttle blades 100% open.... there is little if any vacuum at WOT. If you have a scanner, look at the MAP sensor. That is essentially the "opposite" of vacuum. The scanner will also show you barometric pressure (BAR), and BAR - MAP = vacuum.
PopoFormula
Oct 12, 2015 04:19 PM
Godamnilovemy79
Sep 3, 2015 03:40 PM
97SSdude
Aug 21, 2015 09:36 AM
dkred94z
Aug 20, 2015 03:09 PM
