What kind of cam would be great for a daily driver 95 camaro
Old Sep 12, 2016 | 05:35 PM
Jomueka13's Avatar
I'm looking for suggestions about what kind of cam would be great for a daily driver 95 camaro, one no to aggressive but noticeable difference
Old Sep 12, 2016 | 10:33 PM
Re: What kind of cam would be great for a daily driver 95 camaro
Good topic for "LT1 Based Engine Tech" forum (assuming it's the V8) not in Advanced Tech. I'll move your post there.
Old Sep 13, 2016 | 10:15 AM
Chimera96's Avatar
contact Lloyd Elliott. his 218/224 may be the one for you
LT1 Cam Info «
Old Sep 13, 2016 | 07:07 PM
Jomueka13's Avatar
Old Sep 13, 2016 | 07:08 PM
Jomueka13's Avatar
LT1 Cam Info «
OK, many thanks, I appreciate the help
Old Sep 13, 2016 | 10:42 PM
And you got some good advice......
Old Sep 16, 2016 | 08:42 AM
RUDEDOG's Avatar
Look at the specs on the one in my sig. It makes a lot of power, idles good, sounds good, and passes emissions.
Old Sep 17, 2016 | 01:21 AM
AeroGunzF1's Avatar
224/224, .565"@.050 112 lsa is good for a stock motor minus the cai and exhaust/headers. The Lt4 hot cam sounds great and will work with the stock gears heads and converter if it's temporary and you have a tune obviously
Old Sep 17, 2016 | 12:10 PM
Dtimekw's Avatar
+1 with Lloyd Elliot. Cams usually go with other items like intake,heads and exhaust. You can upgrade your stock cam to a mild one with a stock motor and see a little bit of difference, I think LT1 to LT4 cam swap is popular. Also, the transmission makes a difference in cam selection (manual vs. auto).
An engine is just an air pump. The more air you can bring in, the more power you can make BUT you have to get rid of the air. Basically, larger intake, bigger cam allows bigger heads to swallow that air/fuel and bigger exhaust gets rid of it out the back. Finding the right combo of those parts is hard...........call Lloyd
Old Jan 16, 2017 | 01:12 PM
Jomueka13's Avatar
what kind of cam do you have?
Old Jan 16, 2017 | 04:26 PM
RUDEDOG's Avatar
It's a Comp cam spec's are in my Signature.
Old Jan 16, 2017 | 09:43 PM
He has to scroll up for your signature. It did not show in your last post. Are you posting from a phone? Seems that the signature may no automatically post.
Old Feb 26, 2017 | 03:06 PM
Jomueka13's Avatar
Many thanks for the advice
cmsmith
Aug 17, 2015 06:50 PM
whitehooptie
Aug 10, 2015 07:02 AM
fryguy
Jul 29, 2002 08:16 AM
whuzizname
Mar 21, 2002 08:21 PM
JediBandit
Nov 13, 2001 08:01 AM
