What just happened???
Old Feb 10, 2004 | 06:29 PM
Mitch666's Avatar
Well, I think Ive run into my first lt1 problem. I was just running out to my gfs house and my car started fine and went down the drive way fine. Then i stopped to check my fog light because the left fog light is out. So parking brake on and such, i get back in lower the parking brake and my parking break warning light is still on, then it says ABS INOP. So I am driving around my neighborhood and i turn off my radio and I hear this kind of mini supercharger sound and my electricity to the car keeps stuttering?? I have no idea whats wrong because it started up fine and then it got messed up when I started driving. The only thing I have done recentely was switched my head unit, but it did have wires from subs and amps and install a trick flow elbow. Also when me and my friend where installing my head unit, the security light for the alarm (aftermarket, codec alarm) got disconnected and my alarm stopped working(like beeping when I locked it and unlocked). Any ideas??? Sorry its so long!!! Thanks Guys.
Old Feb 10, 2004 | 06:49 PM
nitropatch's Avatar
you should check your sensors by the calipers, maybe one of your sensors went out.
Old Feb 10, 2004 | 06:57 PM
Spinner's Avatar
ABS INOP can be caused by a third brake light out. Check that.
Old Feb 10, 2004 | 07:06 PM
nitropatch's Avatar
my third brake light is out but i dont have a abs inop light on so somtimes it works and sometimes it doesnt i guess.
Old Feb 10, 2004 | 07:11 PM
Mitch666's Avatar
HMMM. What does the have to do with my parking computer thinking my parking brake is still on?? Could it be a fuse?? Should I take my care to a shop or does anyone have a ideas?? Thanks again.
Old Feb 10, 2004 | 07:12 PM
Mitch666's Avatar
Forgot to ask?? Does anyone think this problem will result in like hundreds of dollars in repairs and new parts because that would suck...haha...why!!
Old Feb 10, 2004 | 07:19 PM
scoobysnax83's Avatar
maybe its just the switch on the parking brake. I'm sure the computer is like whoa hold on. Put down your brake
Old Feb 10, 2004 | 07:25 PM
Spinner's Avatar
IF your BRAKE and your ABS INOP light is on, my bets are it's a bad third brake light.
Old Feb 10, 2004 | 07:40 PM
1.8ttolt1's Avatar
um, the brake and abs inop light may also come on when the alternator is taking a crap. since you said your voltage is stuttering i would investigate the alternator. i just went through this and a new alternator fixed everything right up.
Old Feb 10, 2004 | 09:11 PM
Mitch666's Avatar
How can I check the alternator and how can I check the third brake light?? Just see if its not coming on?? Thanks for all your help, keeo it comin!
Old Feb 10, 2004 | 11:08 PM
Well, the third brake lights pretty obvious Someone stands behind the car while someone hits the brakes. The alternator needs to be taken off and taken to A-Zone, they will test it for free.
Old Feb 11, 2004 | 12:02 AM
LS1_03's Avatar
Or if you're absolute friendless, you can get a damn brick and throw it on the brake pedal.
Old Feb 11, 2004 | 12:10 AM
Or the club or a stick, or back up to a somewhat reflective surface and look. As you can see I'm friendless.... No, not really, just all my friends don't know shiat about cars....
Novo
Jun 14, 2016 02:58 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
