What intake manifold is this?!
Old Oct 22, 2003 | 03:39 PM
RamAir95TA's Avatar
GM part number 10108630. I was told it was a stock manifold, but it appears otherwise....
Stock ports are supposed to be 1.058" high x 1.158" wide x 2.050" tall. The ports on this manifold are 1.281" high at the bottom AND top (symmetrical), and 2.093 tall.
http://www.fbodythunder.com/ramair95.../manifold1.JPG
http://www.fbodythunder.com/ramair95.../manifold2.JPG
I have started hand polishing it for my heads/cam swap, but now I'm a little concerned. Any clue?
Old Oct 22, 2003 | 03:50 PM
Fastbird93's Avatar
Got me??? How well does is mate up with a set of heads, or have you checked?
Old Oct 22, 2003 | 03:57 PM
RamAir95TA's Avatar
Hey Sean...
I haven't checked yet. I'm picking up a spare set sometime next week...I'm awfully curious though.
Old Oct 22, 2003 | 04:01 PM
BigJustinZ28's Avatar
could that be an unpainted lt4 intake ??? I know its ports are bigger. Or maybe its off a truck or something ?
Old Oct 22, 2003 | 04:05 PM
Fastbird93's Avatar
That's actually what I was thinking.
Joe, upping the ante on the beast??? When are you planning on being done?
Old Oct 22, 2003 | 04:27 PM
RamAir95TA's Avatar
I was also thinking that as well, but the part number on the LT4 manifold is 12550630. Mine is 10108630. Odd...
Yeah...she's getting some goodies. I'm sick of this bolt-on crap. Should be done around February...and she'll be NASTY.
If it isn't going to match with my LT1 heads...I'm going to have to melt it down and make something out of it I guess...maybe a nice set of bookends.
Old Oct 22, 2003 | 06:21 PM
Fastbird93's Avatar
That, or you could find some heads to match up!!!!
What's your setup going to be, cam and all that?? I'm getting ready to swap some 1.7 rockers onto my 224/230 car hopefully within the next month. I just had to order an opti today to hopefully fix my problem.
Old Dec 15, 2008 | 06:45 PM
94Z28rag's Avatar
BUMP for a very old thread that has sparked my curiosity...any ideas???
Old Dec 15, 2008 | 07:14 PM
Joe B's Avatar
Yea, there are two common port styles of LT-1 intake manifolds....One with more of a tapered smaller port entry... and the other, which is considered to be slightly more desirable (in stock form) that has MUCH more open rectangular ports......after full porting by someone like Lloyd Elliott , they end up the same(port potential wise)....It's just the type with the smaller more tapered ports just takes more aluminum removal to get it where it needs to be.....(For example: On the larger port manifold, Lloyd usually removes "about" 2 LBS of material for his full LT-1 manifold port.....and on the smaller tapered port intake, it's closer to 3 LBS of material removal...............Joe
Old Dec 16, 2008 | 09:29 AM
94Z28rag's Avatar
Thanks for the heads-up...awesome car, btw!
Old Dec 16, 2008 | 06:09 PM
Joe B's Avatar
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
