What is the IH for the ex 612 spring?
Old Aug 21, 2004 | 05:46 PM
Shayne's Avatar
If someone has some info that would be great.
Thanks Shayne
Old Aug 21, 2004 | 07:31 PM
chrism400's Avatar
Re: What is the IH for the ex 612 spring?
It's 1.750". I put some on bought from combination motorsports.
Old Aug 22, 2004 | 01:03 PM
Shayne's Avatar
What kind of shim and how thick were they? Did yours come with shims?
Thanks Shayne
Old Aug 22, 2004 | 02:13 PM
WS6T3RROR's Avatar
nobody can tell you exactly what shims to use without messuring each spring pocket with the retainer and lock thats going to be used on that valve. and they wont all be the same either the hieght will vary from valve to vavle on the same head. if its really that important to you buy what i call a barrel mic which will tell you installed hieght basicly you just assemble the retainer and lock with the mic in place of the spring and then screw it out until its fairly tight. then shim accordingly to hit desired installed hieght. i usually buy a pack of comp shims when i do a set of springs they come in assorted sizes and they're certain diameters as well.
Old Aug 22, 2004 | 04:14 PM
chrism400's Avatar
Shoebox used 612 springs and measured them and they came out right. They are supposed to be direct replacements - height, size etc... I never measured mine, I used the stock spring cup and retainers and locks. Everything seems to be ok but I really don't know for sure where things ended up. I am just taking my chances.
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Catmaigne
Jul 14, 2015 05:17 PM
