What is Hole on Front of Intake For?
Old Apr 24, 2009 | 05:11 PM
Hal Fisher's Avatar
Got my intake back from the powerder coaters but they left a cork (I think) in a hole that's in the front of the intake, below the 3 holes for the throttle body. Does a bolt go there to block it off or is it for a vacuum connection? You can see the spot in question in the picture, it's the painted round part down by the bottom.
Hal
Old Apr 24, 2009 | 05:19 PM
96capricemgr's Avatar
PCV connection.
edited to correct brain fart.
Old Apr 24, 2009 | 05:32 PM
No. In the 95-97 LT1's that is where the PCV valve vacuum line connects. In the 94's, it is plugged with a pipe plug. Not sure what, if anything was attached there in the 93's.
Courtesy of Shoebox:
http://shbox.com/1/pcv_pipe.jpg
Old Apr 24, 2009 | 05:56 PM
Hal Fisher's Avatar
Thanks guys! I'll check into those. I hate all these vacuum lines, too easy to forget which is for which.
Hal
Old Apr 24, 2009 | 06:09 PM
That's why they put the vacuum line diagram on top of the radiator cover.
Old Apr 24, 2009 | 06:12 PM
Hal Fisher's Avatar
Oh, you mean the cover that holds the diagrams that I have to take off before smog inspection
(Not that I'm am withholding anything important and it easily passes smog)
Hal
Old Apr 24, 2009 | 07:21 PM
Yeah you are right, I knew what it was just typed wrong . I am going to go back and change it to avoid confusion.
I believe that hole is missing on the 93s
Old Apr 25, 2009 | 09:39 AM
user 647483's Avatar
Correct, there is no PCV connection on the front of a 93 manifold.
It's on the side of the manifold, so the PCV tube is a U shape.
Old Apr 25, 2009 | 08:56 PM
94zgreenmachine's Avatar
When I switched to the vented opti, I used that hole to mount pcv vac. line .
Old Apr 27, 2009 | 01:21 PM
Hal Fisher's Avatar
Is this the connection with the metal line with rubber connectors on both ends?
Hal
Old Apr 27, 2009 | 03:03 PM
z275plus's Avatar
When you put the tbody on , I think that hole will be covered?
Old Apr 27, 2009 | 03:54 PM
Nope
Old Apr 27, 2009 | 05:22 PM
He's not asking about the open, black hole right below the throttle body bores. He's asking about a hole about 2" below the TB bores, that has a cork in it, and is covered with powder coat, making it almost invisible in the picture.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
rjc1629
Jan 27, 2015 10:46 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
