What heppens if you reve?
Old Oct 14, 2006 | 01:27 PM
davidc212k's Avatar
Im a nub with cars.
I have a 1995 Camaro z28.
I was wondering. What heppens if you reve the car to much?
Old Oct 14, 2006 | 01:29 PM
#2's Avatar
Re: What heppens if you reve?
it's not really great to just sit there and rev it (actually, it's pointless). as long as you aren't bouncing of the rev limiter or holding it at high rpms it's not real bad.
i don't recommend reving it for no reason though.
Old Oct 14, 2006 | 01:31 PM
davidc212k's Avatar
Why not??
What bad does it do to the car?
Old Oct 14, 2006 | 01:47 PM
Klypto's Avatar
prob wont do anything, but... why do it? revving it to rev at someone is no big deal at all.. but to just rev, and if you do it 24/7... i guess maybe it COULD cause damage, but even then, unless your revving to 6k all the time (which is retarded) shouldnt do anything
Old Oct 14, 2006 | 01:51 PM
davidc212k's Avatar
Thanks guyz. that means i wont rev it again. You are right there is no point on just reven it for a stupid reason.
Old Oct 14, 2006 | 01:54 PM
30696bird's Avatar
I was bouncing off the rev limiter (6700 rpm's doing a burnout ) and ruined a lifter. So yes, reving is bad for the engine. Not to mention that on a stock ignition system it cuts the fuel and not the spark to your engine, running lean is BAAAD for your engine.
Old Oct 14, 2006 | 01:55 PM
2001NBMZ28's Avatar
I let someone rev mine at a cruise in once cause they wanted to hear my exhaust - car threw a P0300 misfire code, probably hit the rev limiter.
Old Oct 14, 2006 | 02:07 PM
Justin Horne's Avatar
Well.. Nobody's saying NOT to.. THey're saying, don't hold the pedal to the floor and tune the radio while you do it.
Tap the pedal down, throw it to ~4500, and enjoy. Sure, don't do it at every single stop sign over the life of your car, but if somebody wants to listen to your engine, it's not gonna hurt your car.
Remember: 4500 is fine, even 5900 is probably fine, just don't hold the pedal to the floor and let the computer tune it down for you.
Old Oct 14, 2006 | 02:14 PM
JakeRobb's Avatar
Super Moderator
Revving is okay, in general.
Spinning the engine causes wear, and the faster it spins the more quickly it wears. Extremely high RPM can break parts (see post #6).
Hitting the rev limiter means that the computer is cutting fuel to prevent you from revving any higher. Cutting fuel means a lean mixture, which means a hotter burn, which can in time mean burning a hole through a piston (for example).
Avoid hitting the rev limiter, and know that the parts on your car are going to wear out eventually, just like every other car. Other than that, have fun!
Old Oct 14, 2006 | 02:34 PM
evilundisguised's Avatar
Doing a burnout is not quite the same as sitting in neutral and revving... Has anybody ever melted a piston due to revving at a stand-still? Technically pure air is a "lean mixture", but I won't believe that pumping pure air at high RPMs through your engine is going to cause detonation.
Old Oct 15, 2006 | 11:47 PM
"cutting fuel" means there is no fuel there for the air to burn = no combustion. Its not going to hurt it, or "burn a hole through a piston". With nitrous, some people get nervous about curring fuel, because the feel the extra oxygen that's present may burn the red hot exhaust valves.
Old Oct 15, 2006 | 11:50 PM
Klypto's Avatar
when i said rev engine, i didnt mean to bounce off limiter lol... ive maybe done that 1-2 times on accident for maybe a half a sec... hah i know that will hah
Old Oct 16, 2006 | 06:05 AM
95z28man's Avatar
sitting there and revving the engine is just a waste of gas.
dkred94z
Sep 22, 2015 11:24 AM
FredM
Jun 5, 2015 05:45 AM
Rde Bandit
Mar 21, 2015 10:17 PM
Pentatonic
Aug 4, 2003 12:49 AM
Jun 13, 2003 08:41 AM
