What the hell is this thing?
Old Jul 18, 2005 | 04:17 PM
chevyman502bb's Avatar
this is between the fuse box and the air filter in my 95Z
http://photobucket.com/albums/y88/Mo...t=S3010027.jpg
http://photobucket.com/albums/y88/Mo...t=S3010026.jpg
Old Jul 18, 2005 | 04:26 PM
TruDualed95Z's Avatar
Re: What the hell is this thing?
time bomb
Old Jul 18, 2005 | 04:38 PM
i jus looked at it again and its spliced into the fan relay.
Old Jul 18, 2005 | 04:40 PM
pillagenburn's Avatar
If i had to guess, i'd say its used to change the temperature at which the fans turn on. Just a guess!
97BBlackZ's Avatar
kind of looks like something that could be used to set when the fans turn on or something like that.
Old Jul 18, 2005 | 04:41 PM
then wouldnt it be spliced into the temp sensor? or does the temp sensor and fan run through the same system?
Old Jul 18, 2005 | 04:48 PM
Ricardo's Avatar
The temp sensor voltage is used by the PCM to turn the fans on and off according to the programmed temperatures. The PCM does this thru the relays. Your temp switch seems to be wired in order to override the PCM.
Old Jul 18, 2005 | 05:05 PM
matt65's Avatar
Never Seen one of those. I'd take it off...carefully.
guywithaZ's Avatar
I think I have one of those on my oven...
Old Jul 18, 2005 | 05:38 PM
it controls the temp the fan kicks on. thanks guys.
Old Jul 18, 2005 | 06:14 PM
ReNxWar's Avatar
Woah, haven't seen one of those before.
Old Jul 18, 2005 | 06:17 PM
mr_will's Avatar
flux capasitor???
Magenta_Hearts
Mar 25, 2015 10:24 AM
NewsBot
Mar 19, 2015 12:20 PM
heavenly_six
Dec 10, 2014 12:23 AM
Hal Fisher
Sep 14, 2002 09:36 PM
