What the Hell is This???
Old Nov 25, 2004 | 04:23 PM
joecool72's Avatar
What the hell is the tube that leads from the bottom of the intake elbow on the LT1??? And what function does it serve???
I'm sure it serves some purpose but from it having a closed end on the bottom of the tube it simply looks useless!
Old Nov 25, 2004 | 04:41 PM
93LT1355's Avatar
Re: What the Hell is This???
If I'm not mistaken, I do believe it is a silencer tube.
Old Nov 25, 2004 | 05:00 PM
jbird's Avatar
Second that, silencer tube. It's purpose is to help the car meet noise requirements by quieting the air rushing through the intake tract. I think it's common name on here is "donkey dong"
Old Nov 25, 2004 | 06:26 PM
BoobSter-lt1-z's Avatar
Is That Elbow Replaceable...and If So Will The Engine Sound Any Deeper Or Will You Get A Deeper Intake Sound? Any Way You Can
Plug It With A Rag?
Old Nov 25, 2004 | 09:26 PM
chrism400's Avatar
1-877-726-8295 call and ask for Jason Cromer. Ask him to get you the 1LE intake elbow. Make sure you get him the right year of your car so you will get the vented/nonvented opti elbow. The tube is for silencing air intake noise and it is also designed to help reduce reversion and add low end torque. If you ever decide to use an electric water pump CSR type, you have to use the 1LE elbow because the water pump will interfere with the tube. You will also appreciate the extra rigidity the 1LE elbow has over the stock one. It is much easier to put on.
Old Nov 25, 2004 | 10:26 PM
simple's Avatar
"donkey dong"
you can yank it out and make a piece of wood to fit in the hole then seal it with silicone
thats how mine is, works great and was free with a tiny bit of elbow grease
Old Nov 25, 2004 | 10:40 PM
Thanks A Lot For The Responses...so Thats The 'le' Elbow Everyone Talks About...huh...and It Helps In Low End Torque...whats The Price???? And By Getting That Elbow Will The Engine Or That Section Of The Intake Sound A Bit Deeper Or Different????
Old Nov 25, 2004 | 10:42 PM
simple's Avatar
highly unlikely that you will see any gains by removing it, it might become a little bit louder in the intake track but nothing entirely noticeable
thats why i made mine, screw buying the 1LE part
Formula Steve
Sep 19, 2023 08:31 AM
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
whitehooptie
Jul 12, 2015 06:10 PM
NewsBot
Mar 19, 2015 12:20 PM
