What heads for 450+rwhp?
Old Jan 11, 2005 | 09:05 AM
  #16
tireburnin's Avatar
Re: What heads for 450+rwhp?
That 452rwhp car is the exception and not the rule. It was also dynoed on a Dyno Dynamics which reads higher than a Dyno Jet. Our local dyno dynamics reads higher by 20-30rwhp. Most people dyno something crazy, but their trap speed never matches.
No new numbers ever came out for that car, and it never trapped 120mph+ like it should have. Seems like a fluke dyno.
But look at a BIG hydrolic roller or a solid roller to get those big numbers on the dyno/track.
Old Jan 11, 2005 | 09:11 AM
  #17
WS Sick's Avatar
Also consider your compression, a jump from 10 to 11 to one in compression alone is a 2 to 3 percent increse in power , on a 400 horse motor that is 12 hp or so increase just from compression alone.
Old Jan 11, 2005 | 02:28 PM
  #18
bdc95ta's Avatar
ws sick I believe jumping from 10 to 11 is only a 1.5% increase. If money permits focusing on the VE w/ a custom intake and headers combo would yeild a higher % increase.
Just thermal coatings should get you there w/ a decent setup. close to 10% increase w/ just the pistons and chambers.
Old Jan 11, 2005 | 03:33 PM
  #19
WS Sick's Avatar
Here's a nice little compression ratio tool.
http://www.btinternet.com/~mezporting/compression.html
Every little bit helps.
Old Jan 11, 2005 | 08:23 PM
  #20
wicked_95z's Avatar
Well my C/R figures out to be a little under 11.5:1 already.
Old Jan 12, 2005 | 08:55 AM
  #21
WS Sick's Avatar
That should be plenty to get there, you may have to spin it a little over 6500 to truly get there with the big heads, but compression and cam will assist a big set of heads.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
