What heads
Old Feb 6, 2004 | 10:32 AM
JLSZ28's Avatar
What heads
I was wondering what heads i should get. I have the LT4 Hot cam but i was wondering if the lt4 heads are best bet or if there is a better set out there. Any advice would be apprecitated
Old Feb 6, 2004 | 10:36 AM
SVT Killer LV's Avatar
www.trickflow.com
cheaper than those lt4's too
Old Feb 6, 2004 | 10:38 AM
KCFormula's Avatar
There are plenty of head options out there it all depends on what your budget looks like. The hot cam is not that big of a cam, if you don't plan on getting too wild with your car a nice set of ported stock heads from Lloyd seems like they would suit you well.
Old Feb 6, 2004 | 10:39 AM
trickflow
edelbrock
ported lt1's
lt4
afr's
Old Feb 6, 2004 | 05:35 PM
squinn's Avatar
I'm a big fan of the GM LT1/LT4 castings, bigger is not always better.
Old Feb 6, 2004 | 05:45 PM
lt1g3n's Avatar
lt1 ported heads are pretty nice i hear, and can flow pretty well. I wish i could afford some AFR's, that's what i'd buy .. but right now im stuck with stock heads, lost my job today .. so i don't know if i'll even get it started any time soon
Old Feb 6, 2004 | 06:34 PM
12SCNDZ's Avatar
My ported LT1 heads flow 271 CFM @ .550"...With 2.0"-1.56" Manley Pro Flow valves. I spent $1100 to have them ported.
Frank
Old Feb 6, 2004 | 06:37 PM
Wild1's Avatar
Depends on the compression ratio you want too... Depending on cam, you'll want to dial in your Dynamic Compression Ratio based on the cc's of your heads. Also, are you planning on any block work? That will have a factor in the type of head...
Sorry to hear about your job
Old Feb 6, 2004 | 07:59 PM
FlyboyZ28's Avatar
I got a set of Total Engine Airflow lt1 ported heads that I have heard good things about. Talk to Brent at www.totalengineairflow.com lots of help.
Dan
Old Feb 6, 2004 | 08:09 PM
simple's Avatar
listen to the fast guy
Old Feb 6, 2004 | 08:14 PM
FlyboyZ28's Avatar
i didnt realize that either, but if that guy is runnin lt1 castings.....WOW!
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
