What head Gaskets you running??
Old May 16, 2012 | 11:22 PM
CamDriver's Avatar
just wondering what head gaskets everyone is running?? my motor No nitrous, should be 11 or 11.25 with a .028 gasket...
Old May 16, 2012 | 11:27 PM
RamAir95TA's Avatar
Re: What head Gaskets you running??
Custom .032" Cometic MLS gaskets.
Old May 17, 2012 | 02:26 PM
CamDriver's Avatar
thanks!! i was thinking about them
Old May 26, 2012 | 06:15 PM
aboatguy's Avatar
Custom cometic .027 MLS
Old May 27, 2012 | 04:01 AM
96capricemgr's Avatar
Look into the Victor Rienz/Mr. Gasket .026 so long as the pistons are at least .005 down.
Old May 29, 2012 | 12:32 PM
Mystery Bird's Avatar
Victor's .026 here.
Old May 29, 2012 | 01:17 PM
Bersaglieri's Avatar
I run these on both of my cars. Beware of how they are packaged and double check the gasket before installing. My last set that had black cardboard were packaged wrong, got a replacement set with blue cardboard and they were packaged better/differently.
-Dustin-
Old May 29, 2012 | 01:35 PM
The Victor packaged sets have always been fine, and last packaging I saw from Mr. Gasket was finally right.
There are lots of options but for some reason nobody ever wants to include any info about how they want to use something.
I mean a stock shortblock is likely .020+ down in the bore, at that you want as thin a gasket as you can get, but a built motor might be zero decked and if it is a .026 gasket is not the right choice.
I forgot to mention these are the same gasket sold under two different brand names and Victor is an OEM supplier.
Old May 29, 2012 | 03:37 PM
Orr89rocz's Avatar
Some tight piston to head deck clearances in here or are your pistons in the hole a little ways?
I like MLS gaskets if the surfaces are smooth/clean/well machined.
Old May 30, 2012 | 06:53 AM
Most of the guys doing "built" LT1s aim for .032-.035 quench, we can get away with lots of compression and good quench helps detonation resistance further helping us get away with more compression.
The stock b-body gasket is popular too and is .029 Felpro is .039 and stock f-body is .049
Old May 30, 2012 | 09:15 AM
Orr89rocz's Avatar
Just seems alittle tight below .035". With thermal growth and rpm, thats getting abit closer to the head but should still have some room. I've always used .040-.041" gaskets with good success, zero deck blocks. I've used the Fel-pro MLS's before. Good success with those. There was an older black coated version and they changed to a blue coated version. Have heard some issues with leaks with the blue version but I didnt seem to have any problems on my boosted motor. I have cometic now tho.
Old May 30, 2012 | 10:02 AM
zmike's Avatar
Victor Reinz .026 and has been fine so far (almost a 1k miles).
Old May 30, 2012 | 11:28 AM
ACE1252's Avatar
Fel-Pro 1074 here.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
