what happens when you unplug the IAC?
Originally posted by scoobysnax83
It should stay at whatever position it was at when you disconnect. Shoudn't it?
Originally posted by shoebox
Yeah, that's what it will do, but when you plug it back in, it will be way out of synch with the pcm. It's best not to unplug it while it is powered up.
Originally posted by anasazi
how do you get it re-synched?
This is supposed to work:
IAC reset
-Depress accelerator slightly
-Start engine, then release accelerator pedal, run engine for 5 seconds
-Turn ignition "OFF" for ten seconds
-Restart engine and check for proper idle operation
I suppose if it is too far off, you might have to try that a couple of times.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
autoxr166
Sep 25, 2015 04:21 PM
tdigger9899
Sep 7, 2015 10:56 AM
