what happens when you unplug the IAC?
Old Jul 10, 2003 | 04:13 PM
anasazi's Avatar
what happens when you unplug the idle air controller? will it stay in its current position?
Old Jul 10, 2003 | 04:29 PM
'94 Bad A Z28's Avatar
Car will stay reved at about 2500 rpms.
Old Jul 10, 2003 | 05:40 PM
scoobysnax83's Avatar
It should stay at whatever position it was at when you disconnect. Shoudn't it?
Old Jul 10, 2003 | 06:10 PM
Yeah, that's what it will do, but when you plug it back in, it will be way out of synch with the pcm. It's best not to unplug it while it is powered up.
Old Jul 10, 2003 | 06:20 PM
anasazi's Avatar
how do you get it re-synched?
Old Jul 10, 2003 | 06:35 PM
Why did I know you were going to ask that?
This is supposed to work:
IAC reset
-Depress accelerator slightly
-Start engine, then release accelerator pedal, run engine for 5 seconds
-Turn ignition "OFF" for ten seconds
-Restart engine and check for proper idle operation
I suppose if it is too far off, you might have to try that a couple of times.
93 RedBird
Nov 15, 2015 08:24 AM
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
autoxr166
Sep 25, 2015 04:21 PM
tdigger9899
Sep 7, 2015 10:56 AM
