what happens when the TPS sensor is bad?
Old Apr 8, 2003 | 04:45 PM
steelheart's Avatar
i have been having a high idle problem, what are the common symptoms of a faulty TPS SENSOR, im thinking that may be why my car is idleing high and droping back to normal after about 10 seconds of idleing up near 2200-2300 rpm then it will drop back to normal idle.. thanks guys
Old Apr 8, 2003 | 05:31 PM
motox13's Avatar
Re: what happens when the TPS sensor is bad?
the tps doesn't usually disrupt idle quality, in most cases you will notice problems accelerating. the tps sensor tells the computer what you are doing with the gas pedal, if you are having trouble with your idle you may want to check the iac position and how it is acting. check this with a scan tool. also pull your codes.
Old Apr 8, 2003 | 05:56 PM
cals400ex's Avatar
yeah, take out your iac and clean it with some carb cleaner. shoebox has the location and such on his tech page. search for shoebox and that should help you out. let us know if that was your problem.
Old Apr 8, 2003 | 06:13 PM
steelheart's Avatar
ill clean it tomorrow and see what happens..ill let you know..
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
Fatdog2
Feb 13, 2015 08:19 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
