what fuel pressure to run with cam
Old Jul 25, 2004 | 10:26 AM
huskersZ's Avatar
I recently installed a 227/233 xe cam. What fuel pressure should I use with the stock injectors. On stock cars, I know that you lean the fp out to about 38-39, but I figure now, it needs to be more than stock
Old Jul 25, 2004 | 12:09 PM
96capricemgr's Avatar
Re: what fuel pressure to run with cam
The right way to do it would be to leave the pressure stock(and the regulator) and get pcm tuning to get the whole fuel curve and timing right. You are looking to push the stock injectors awefully far though, contact a tuner or your tuner and get a tune setup for a pressure they recommend and set it to that pressure which will be a bit higher than stock in order to make injectors that are too small work. You can not properly tune a car without pcm work, you can apply a bunch of bandaid fixes and waste a lot of money trying.
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
