500+ rwhp
Old Jul 24, 2004 | 12:51 PM
ZPower_123's Avatar
500+ rwhp
I have a stock 94' Z28 M6
what would it take to get 500+rwhp out of the LT1?
and about how much would it cost ?
Old Jul 24, 2004 | 01:10 PM
mattybz28's Avatar
Re: 500+ rwhp
Naaaawwwzzz
Old Jul 24, 2004 | 01:16 PM
StreamlineZ28's Avatar
Re: 500+ rwhp
do a little research. for what you want first.
Old Jul 24, 2004 | 02:34 PM
disco192's Avatar
Re: 500+ rwhp
you are gonna need 400+ cubes, BADASS heads, and a BIG cam....
As well as a new TB, headers....
It isnt gonna be cheap by any means. You might want to reconsider and try 450 rwhp... 500+ rwhp is gonna run you 2-3x more than 450.
A buddy of mine has a 383 with beefy forged internals and he is putting out 450 rwhp on a massive custom cam and TEA heads. He also sprays 250 DP nitrous... so he has 700 rwhp... its a sick ride.
Old Jul 24, 2004 | 03:36 PM
Dave88LX's Avatar
Re: 500+ rwhp
Sounds to me like you don't really want 500rwhp, you just want a # to impress your friends.
What do you want to do with the car?
Old Jul 24, 2004 | 03:50 PM
bowtieforpower's Avatar
Re: 500+ rwhp
if i were you i would build a 355 with an ati procharger. i have seen some kickass results with that. of course you will need some good heads and a good cam. you dont need nitrous, but you could use it to be even faster than you would be with the 355. price varies due to where you get the parts and who you have do it.
Old Jul 24, 2004 | 04:44 PM
1984camaroz28's Avatar
Re: 500+ rwhp
if u did a 383 with a t-trim a set of loyed Elliot heads and a big cam u will be making alot more then 500rwhp. my setup makes 575rwhp with 12psi of boost. Its not gona be cheap by no means. plan on 2500$(used) for the supercharger alone
Old Jul 24, 2004 | 06:04 PM
Mindgame's Avatar
Re: 500+ rwhp
How much are you prepared to spend to meet that goal?
And yeah... I know everyone gets upset when another member mentions a HP goal but some just need to get over it. Everyone is in this hobby for different reasons.... some want HP, some want TQ and some just want low ET's. Who cares.
-Mindgame
Old Jul 24, 2004 | 11:58 PM
SS MPSTR's Avatar
Re: 500+ rwhp
This and you need to be honest about what your expectations are for the car.
500rwhp is expensive, and high maintenance.
Old Jul 25, 2004 | 12:21 AM
Somnambulist's Avatar
Re: 500+ rwhp
you can build anything if you have the $$$
gotta have the cash to put down HP numbers like that
Old Jul 25, 2004 | 10:38 AM
SAR2K's Avatar
Re: 500+ rwhp
Easiest & cheapest route is N2O. Do a mild 355 build up and hit it with a small shot & you're there. 95Bird just made 503rwhp & 535rwtq with a 75 shot on his 355... through 4.71 gears at that. He has approx $3,500 in the motor itself and the cost of the N2O kit & associated components.
Steve...
Old Jul 25, 2004 | 12:05 PM
Transamdriver's Avatar
Re: 500+ rwhp
Im going for 500+rwhp with my setup, I have tons of money in mods to do it right and Im using Nitrous.
Here are all the mods exactly:
Exhaust:Hooker Long Tube Headers coated by Jet-hot, Mufflex 3" into 4" Y-pipe, Hooker 3" Cat-back Exhaust, QTEC Electric cutout, PCM:OBDI Conversion, Tuning by Brian @ PCMforless, LT4 knock module, "Bolt-Ons":Ported MAF, SLP cold air intake, K&N Airfilters, Fan switch over-ride, Hyptertech 160 thermostat, Meziere electric water pump,Ignition: MSD 6AL, MSD coil, MSD digital window switch, TR OVC wire kit, NGK TR6 spark plugs, Internal Engine: CC306 cam .510 INT .540 EXH 229*INT 245 EXH 112*LS, Comp Pro Mag S/A 1.6 rockers, Crane 10308 springs, Comp Hi-tek pushrods, AFR hydra-rev kit, GM extreme duty timing set, Power adder:Nitrous works 75-175 shot, Bottle heater, and Nitrous works purge, Transmission:Precision 3200-3600 stall converter, Trans-Go shift kit, B&M supercooler,B&M deep pan, Fuel System:Racetronix fuel pump system with Walbro 255,Suspension:BMR Tubular lower control arms, BMR LCA bolt-in drop brackets, Spohn Adjustable Torque arm, BMR SFC's.. Track: 26x10.5 ET streets on salad shooters, front Weld 15x3.5" prostars. Comming soon: holley 52mm TB, Hurst line lock, HAL QA1 front shocks.
Old Jul 25, 2004 | 12:32 PM
neil350's Avatar
Re: 500+ rwhp
Healthy heads and cam from Sar2K, Ai, Lloyd Elliot with a 100 shot of gas, would get you there easily.
RUENUF
Mar 13, 2016 03:37 PM
95chwagon
Oct 16, 2015 12:24 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
