What Exactly is a lean Condition?
Old Aug 22, 2003 | 02:56 PM
stuart69427's Avatar
Does this mean low fuel pressure?
I assume this is a lean a/f ratio which could mean that either there is a low fuel pressure or low air coming into the engine. Is this correct???
Old Aug 22, 2003 | 03:09 PM
Camaro_Maniac63's Avatar
Lean means there is either too much air (highly unlikely unless you have Forced induction of some sort) or there is not enough fuel going into the A/F mix to keep the ratio around what is considered to be perfect (14.7:1 I believe is perfect).
Old Aug 22, 2003 | 03:14 PM
Lyle A's Avatar
And the cause isn't necessarily low fuel pressure.
Old Aug 22, 2003 | 07:28 PM
How would one see if they had a lean condition?
I just checked my fuel pressure and it wa a constant 40psi while ignition-on-engine-off and a constant 36psi while ingition-on-engine-on.
According to the book my guage came with, this is ok since I do see a vacuum line connected to my fuel pressure regulator, is this correct???
I have a 3.4L... Is this good?
It started storming so I couldn't check the resistance of the injectors
Where can I get a injector test light at?
Old Aug 22, 2003 | 07:57 PM
Lyle A's Avatar
The GM manual says your fuel pressure at the test connection with ignition ON engine OFF should be between 41 to 47 PSI. Connecting a scan tool will show if you are running lean or not. Lean conditions usually cause your engine to run hot. Your gauge showing 40 PSI may not be a problem. If your fuel presure is greater than the injector rating ,with the engine running, you should be ok as far as fuel pressure is concerned. I can't find anything to tell me what type injectors you have.
Old Aug 22, 2003 | 08:56 PM
Zack's Avatar
lean= too much air
rich=too much fuel
Old Aug 23, 2003 | 02:37 PM
I think I found that info. I am pretty sure they are 17Lbs Injectors. Does this sound right?
Info found here:
http://engine.firebirdv6.com/
I have 40psi engine-OFF and 36psi engine-ON. Is this good? (Both with Ignition ON)
Old Aug 23, 2003 | 04:01 PM
Lyle A's Avatar
I think you have sufficient fuel pressure. especially if your injectors are 17 psi.
Old Aug 25, 2003 | 12:37 AM
Thanks for the help! I will search for my problems elsewhere!
grr... emissions...
Henson071
Sep 18, 2015 04:01 PM
4586
Aug 18, 2015 07:08 AM
Henson071
Aug 4, 2015 09:32 AM
Boss002
Jul 24, 2015 10:47 AM
Noct
Jul 14, 2015 01:18 AM
