What engine fluids would cause a flash fire.
Old May 10, 2004 | 06:28 AM
wicked_95z's Avatar
My friends 97 z that we just rebuilt the motor and put long tubes has something leaking onto the headers and making fireballs. The underhood is pretty hot and the headers are even ceramic coated but we can see where fluid has been running down near the collector and twice now he has had fireballs come out form under the car? Any ideas?
Old May 10, 2004 | 01:56 PM
Mtrhds94Z's Avatar
Gasoline is all I can think of that would be a problem..
Old May 10, 2004 | 02:23 PM
JasonL's Avatar
I have seen flames from oil leaking onto headers. At an autox. It was both exciting and scary
If it were gasoline I would imagine the whole car would have been torched by now.
Old May 10, 2004 | 02:42 PM
faded93bird's Avatar
break fluid will do the trick also
Old May 16, 2004 | 08:38 PM
wicked_95z's Avatar
Would power steering fluid do it?
Old May 16, 2004 | 09:20 PM
magius231's Avatar
I think its safe to assume that most fluids would flash at the temperature your headers are at...can you trace down the leak at all? WIpe everything off then run it and check again?
PCLZ28
Dec 24, 2015 05:19 PM
Deadbolt24
Jan 19, 2015 01:29 PM
David Dorris
Jan 17, 2015 08:10 PM
Jul 4, 2005 05:00 PM
Timberwolf
Aug 9, 2002 11:24 AM
