Code 23 MAT is too Low?
Old May 16, 2004 | 03:15 AM
Johnny-Z-Man's Avatar
I just did a scan using my AutoXRay EZ Scan 3000 and pulled up a "History Code #23 MAT is too Low"
I cleared the code, and ran a live data scan and noticed my Manifold Air Temperature is reading an erratic -40.0 F to +225.00 F leading me to believe I have a bad sensor.
My stupid question is which sensor? MAF? IAT? MAP? or is it something else?
Old May 16, 2004 | 03:52 AM
97WS6SCharged's Avatar
I believe it's the IAT sensor. You could unplug it and then try to monitor it again.
Old May 16, 2004 | 08:56 PM
I think I may of had a bad connection on the ground wire as both connector wires broke off after inspecting that connection.
Since I use a IAT relocator kit, the heavy connector may of loosened up the wire connections.
When I ran the live data test again, w/ no sensor, it read a steady -40F with no erratic Temp numbers.
I'll work on this again latter, thanks for your help!
Old May 16, 2004 | 09:24 PM
Follow up: Indeed that's all the problem was, a broken IAT wire connection.
It's repaired, and my Z 's full performance has been restored!
Thanks again!
Mar 13, 2015 07:15 AM
Jan 23, 2015 01:13 PM
Dec 1, 2014 08:08 AM
91Bird305
Aug 8, 2002 12:36 AM
91Bird305
Aug 5, 2002 01:39 PM
