What else would cause hesitation.
Old Jun 22, 2003 | 01:14 PM
zman613's Avatar
Angry What else would cause hesitation.
Hesitation/stumble from idle-2000 rpms when the motor gets hot. No problem when its cold or when it gets above 2k.
Already changed opti, coil, coil module, plugs+ wires, pcv valve, fuel filter, and cat. Since it only happens when it gets hot, I was thinking about putting in a 160 degree t-stat to keep the temps down. Does this sound logical. My car will get up to about 240 degrees now. Im just out of ideas on how to solve this problem.
Old Jun 22, 2003 | 03:55 PM
zman613's Avatar
I know I'm not the only one with this problem. There has to be someone who has solved this mystery. Or at least, someone with an idea. Please help, this is driving me crazy!!
Old Jun 22, 2003 | 04:53 PM
$hawn's Avatar
Maybe the egr valve or the O2 sensors.
Old Jun 22, 2003 | 05:25 PM
zman613's Avatar
The o2's are new, would the egr need to be changed, or just cleaned? What would be wrong with it to cause problems?
Old Jun 22, 2003 | 05:27 PM
RRios8191's Avatar
EGR Valve
Where is the egr located and how would you clean it?
Old Jun 22, 2003 | 05:28 PM
95 Z/28 LT1's Avatar
Super Moderator
Try cleaning the PCM ground.
You have to take the stud out of the body and clean it really well.
Old Sep 4, 2003 | 12:26 AM
Stormman's Avatar
How doe ones go about this, getting it out of the body. I have seen you post this idea in many idle/hesitation threads. I have tried changing o2's map tps iat cleaned my tb & iac & maf and still have this God forsaken problem. I was gonna look into a coil swap but before I spend more $$$ I weant to try your idea. I know the stud you are reffering to, but I wonder how to gret it out of the fender.
Thanks for your help...
Old Sep 4, 2003 | 08:30 AM
Smoke T/A's Avatar
Re: EGR Valve
The egr valve is located on the driver’s side rear of the intake manifold. It is a black round object that has one vacuum lone coming out of the top. You can clean it by taking it off and spraying it down with carb cleaner. But that wont help if the diaphragm is shot. hth
Joe
ad356
Apr 11, 2015 08:49 AM
9formula4
Jul 16, 2007 03:47 PM
ArcticWhiteZ28
Jul 27, 2005 08:40 PM
meengreen 94z
Aug 5, 2004 08:27 AM
naaz90
Sep 12, 2003 05:47 PM
