What else do I need before header install?
Old Sep 23, 2003 | 04:42 PM
ticket_me_redz's Avatar
Any advice or parts I should buy prior to doing headers. Bolts? Gaskets? Dont want to start it and have to stop in the middle for some $5 part. I know this is a long process....just dont want to get slowed up any more than I know I already am.
Thanks.
Old Sep 23, 2003 | 04:44 PM
Camaro_Maniac63's Avatar
A nice set of bolts + a pair of gaskets should do it. Stage 8 locking bolts work pretty good from what I have seen..
Old Sep 23, 2003 | 05:04 PM
steelheart's Avatar
asprin, band-aids, and a sledge hammer for when you get pissed
Old Sep 23, 2003 | 05:07 PM
Red96Lt1's Avatar
You would probably want to consider doing plugs and wires when you have your headders off.
One other thing, some mechanics gloves might save your hands!!!
Old Sep 23, 2003 | 05:08 PM
sszapper's Avatar
You are gonna need lots of patience. As stated above some good bolts and gaskets. I used stage 8 locking header bolts and fel-pro gaskets. I also needed 02 extensions (only needed if doing long tubes), and just to be on the safe side some OTVC wires. Just take your time and remember it will all be worth it when you start it up for the first time.
rdy2run's Avatar
if you didnt have a tune up in a while now is a good time to do it since the manifolds are out of the way. It is alot easier to change plugs and wires. also buy a good set of header gaskets because you dont want to change header gaskets every week.
Old Sep 23, 2003 | 05:46 PM
carlos64030's Avatar
Buy some heat reflective tape and wrap some around the wires that are in close proximities of the headers. Also wrap some around the spark plug wires, that way none of them will get burnt either. That tape works great for me!
Old Sep 23, 2003 | 06:03 PM
ibanez6rg's Avatar
I used ARP bolts and Fel-Pro (1406) Gaskets... So far, no problems
Old Sep 23, 2003 | 06:09 PM
Thanks to all who responded. Sounds like some good advice. Also sounds like I am in for an experience!!!
Old Sep 23, 2003 | 08:33 PM
Like My Taillights?'s Avatar
Motor Mounts!! If your car has some miles on it they are probably sagging, and your new headers will drive you crazy banging on the floor or whatever else they are near. I had 91K on my car when I did headers and the mounts were really saggy. It was a pain to do the mounts with the headers already on and I wished someone had told me to repalce them. I used the Energy Suspension poly mounts and they seem to work well. They are much stiffer than stock, and only about $25 a peice. save yourself the headaches the later. Good luck. Oh, and don't forget the beer. Lots of it.
Old Sep 24, 2003 | 09:43 AM
Thanks for the replies. Does anyone have specific part numbers for the ARP bolts and Fel-Pro gaskets? Thanks.
Old Sep 24, 2003 | 09:56 AM
Hyperspeed97z28's Avatar
ibanez6rg said felpro 1406's.... Dont know for the bolts.. If your doing !AIR you'll want 2 of the drain plugs in my sig....
Old Sep 24, 2003 | 10:05 AM
i387's Avatar
Originally posted by Like My Taillights?
Motor Mounts!! If your car has some miles on it they are probably sagging, and your new headers will drive you crazy banging on the floor or whatever else they are near. ... Oh, and don't forget the beer. Lots of it.
Great idea! I'm doing headers soon myself. I'll definitely do the engine mounts.
Beer helps, but not too much of it. When you start wondering why there are TWO cars in your one-car-garage, it's time to stop the beer.
Old Sep 24, 2003 | 10:46 AM
bradpreece95z28's Avatar
I used the dead soft aluminum gaskets from percys.....they are killer. After the head work, i RE_USED THEM..yup..and no leaks. well worth 40 some dollars.
Old Sep 24, 2003 | 01:23 PM
ibanez6rg's Avatar
ARP-400-1101 are what I'm using for header bolts. Summitracing.com
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
