What does this sound like to you? fuel pressure stuff
Old May 20, 2003 | 03:09 PM
94FlamdS10Blazr's Avatar
ok i dropped in my 24 pound injectors yesterday and the car took forever to to prime up and start injecting. I mean like 2 minutes of priming. When it started it didnt wanna run right. I just tried the fuel pressure by pressing the schrader(sp?) valve during pump priming and it shoots gas nice and high! after I let go of the valve and the let it prime more , it only shoots out a couple of ccs of gas after the key is off. I pulled the rail with the injectors in it and pressurized it and I know the injectors arent leaking so that eliminates that
the filter is new, the pump is new, the regulator is stock and so are the injectors .
Old May 20, 2003 | 04:22 PM
im about to order a Holley fuel pressure regulator and pump from Holley , you think that would be a good idea to go up to a 255 gph pump?
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
