What does this sound like?
Old Jan 7, 2008 | 09:15 PM
95lt188chevytruck's Avatar
I was thinking timing what do you guys think??
Click here 383-lt1
thanks!
Old Jan 7, 2008 | 09:20 PM
SS RRR's Avatar
The trailer to the next Blair Witch project?
I assume it's being generated from your LT1? Sounds like bearings from an acc. item, of course it's real crappy sound so I'm not sure if that's "scraping" I hear or backfiring.
If it's backfiring then it could be some mixed up plug wires.
Old Jan 7, 2008 | 09:29 PM
95z28man's Avatar
Funny thing this should happen to you too. I just put my h/c in and had almost an identical sound, take a look here:
http://youtube.com/watch?v=tFNPBJTXYyo
Sounds identical huh? And guess what? My timing was off. Turns out I had my dots about an inch or less apart from eachother and cam was in the wrong position.
Dot on cam sprocket should be at 6 o clock, dot on crank sprocket should be at 12 o clock, and the cam dowel needs to be at 3 o clock.
Hope that helps.
Old Jan 7, 2008 | 10:03 PM
Tex95Z's Avatar
Hope that helps.
that sounds like popcorn
to the OP any chance you can get a better quality video?
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
4586
Sep 27, 2015 01:55 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
