What does DA mean when talking about track runs.
Old Dec 22, 2004 | 10:32 AM
93redbird's Avatar
Track altitude?
Old Dec 22, 2004 | 10:49 AM
Re: What does DA mean when talking about track runs.
Track altitude is the elevation of the track above sea level.
Density altitude is the altitude at which the air at standard conditions would be equal to the actual air conditions at the track, reflecting the affects of air temperature, barometric pressure and humidity.
Old Dec 22, 2004 | 11:22 AM
Here's a link that might explain it a little more clearly than I did......
http://www.csgnetwork.com/densaltcalc.html
Old Dec 22, 2004 | 06:21 PM
94 CAMRO Z28's Avatar
You start with track altitude. You then correct this altitude for non standard barametric pressure of 29.92. This gives your your "pressure altitude". Pressure altitude is what your car "feels" like it is at. However, non standard temps will effect the pressure altitude. So you correct the "pressure altitude" for the current temps and this gives you "Density Altitude" .
Aaron
Boss002
Jan 20, 2016 12:17 PM
NewsBot
Jul 8, 2015 06:47 PM
birdblack
Jul 8, 2015 07:23 AM
1996LT1Z28
Dec 4, 2014 09:20 PM
Brady
Jul 29, 2002 10:30 PM
