what does .030 mean
Old Apr 22, 2010 | 08:56 AM
  #16
bombebomb's Avatar
Originally Posted by dangalla
the number indicates the difference from stock
and yes you should be measuring everything anyway, but if the piston says .030 on it then there is an overbore of .030
Yeah I got that much haha
Originally Posted by shoebox
...because it is assumed that you know the engine (stock specs) that you are looking at (an LT1 isn't going to have a 3.000 bore) and the marking is the deviation from stock size. Pistons and bearings have always been marked this way. If was too confusing for folks, I think they would have changed it by now.
Indeed, I guess I was under the assumption they do not make LT1/350 specific pistons (meaning if you had some other CI engine, with a larger stroke, smaller bore equaling the same CI). It is obviously a matter of knowledge on the builder to choose the correct size of course. I am pretty darn sure I put to much thought into this haha.
With all that being said, I understand all .030 pistons are marked as being .030 the stock size.
Z Power
Sep 19, 2015 11:19 PM
Firechicken350
May 18, 2015 09:27 PM
Firechicken350
Apr 22, 2015 12:10 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Austin WS6
Advanced Tech
Aug 28, 2002 12:33 PM
