What doe "splyed" mean. IE: splayed main caps.
Old Dec 19, 2005 | 12:53 PM
wrd1972's Avatar
What the title says.
Old Dec 19, 2005 | 01:03 PM
sw89lt1's Avatar
Re: What doe "splyed" mean. IE: splayed main caps.
i think it means the bolts a not strait in there but at an angle // \\
Old Dec 19, 2005 | 01:16 PM
SStrokerAce's Avatar
It means the outer two bolts on the four bolt cap are at an angle.
Straight 4 Bolt Cap
Splayed 4 Bolt Cap
Bret
Old Dec 19, 2005 | 03:48 PM
Jazsun's Avatar
hmm I wonder what the benefit is to have angled bolts. Dont ls1's use spayed 6 bolt mains.
Old Dec 19, 2005 | 04:05 PM
The LS1 uses four vertical bolts, and two that enter horizontally from the sides.
In theory, putting the outer bolts at an angle could help prevent side-to-side movement of the caps, but there's already the indexing on the block to minimize that. Or, you could surmise that it is done to put the bolt into a "meatier" part of the block's web. But even that is debatable when a block has been designed from the start for the use of four parallel bolts.
Old Dec 19, 2005 | 04:06 PM
No a LS1 cap looks like this...
4 straight and two from the side.
Angled bolts can tie into more material in the block, if there is any more to tie into. I've switched to a 4 bolt main cap register that is wider than the stock 2bolt but it also uses a splayed cap.
Bret
LeftoverChinese
Jan 14, 2024 03:03 PM
Z-rated97
Mar 29, 2015 11:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Patrick Kovack
Mar 8, 2015 09:26 AM
teal98
Aug 18, 2002 11:37 PM
