What do you think of my setup?
Old Jan 25, 2005 | 08:40 PM
Beyonce Knowles's Avatar
I just wrapped up the deal on my head cam package. What you think about the setup.
I'm using a CC306, head flow numbers are:
.200 104 137
.300 136 198
.400 159 242
.500 177 266
.600 188 273
.700 195 274
Also on their way are:
Accel 30 lb/hr Injectors
Comp Cams 1.6 Roller Rockers
Comp Cams Hydraulic Roller Lifters
Isky double coil valve springs
LT1 extreme duty timing chain
I've already got Pacesetter L/T's, CIA and LM exhaust, along with some other stuff in sig. I might should have gone with 1.5 roller rockers. But what do you think?
Old Jan 25, 2005 | 10:32 PM
blackztpi's Avatar
Re: What do you think of my setup?
you'll like the 1.6 rr's better with that cam. matchup sounds good to me, but I'm no expert. not framiliar with those springs. i don't like accel injectors though. u should have opted for svo injectors or something. accels have tendency to stick open. one did on me, flooded cyl 1 causing it to lock up. I tried restarting as the cylinder filled with gas every time. eventually it started....once it bent the rod into a pretzel and pulled the bottom out of the piston skirt, and toasted my brand new shortblock. good thing it was only cast parts, but you should see all the damage it did. ruined crank, 2 rods, all the rod bearings, and 1 piston was destroyed. ruined the block as well. put a piece right into the block and ruined my blueprinted oil pump.
Old Jan 26, 2005 | 01:35 AM
zx1216's Avatar
Lol, you have your exhaust listed first, i was like wtf thats less than stock on the intake The heads look pretty good, you may max out those 30 lb injectors though, if you haven't got them yet u should go with the 36 lb/hr.
Old Jan 26, 2005 | 01:55 AM
simple's Avatar
Beyonce Knowles
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
FryedClutch
Sep 1, 2015 08:24 AM
detroitmuscle
Jul 31, 2015 04:21 AM
