What do you think of my setup?
I just wrapped up the deal on my head cam package. What you think about the setup.
I'm using a CC306, head flow numbers are:
.200 104 137
.300 136 198
.400 159 242
.500 177 266
.600 188 273
.700 195 274
Also on their way are:
Accel 30 lb/hr Injectors
Comp Cams 1.6 Roller Rockers
Comp Cams Hydraulic Roller Lifters
Isky double coil valve springs
LT1 extreme duty timing chain
I've already got Pacesetter L/T's, CIA and LM exhaust, along with some other stuff in sig. I might should have gone with 1.5 roller rockers. But what do you think?
.200 104 137
.300 136 198
.400 159 242
.500 177 266
.600 188 273
.700 195 274
Re: What do you think of my setup?
you'll like the 1.6 rr's better with that cam. matchup sounds good to me, but I'm no expert. not framiliar with those springs. i don't like accel injectors though. u should have opted for svo injectors or something. accels have tendency to stick open. one did on me, flooded cyl 1 causing it to lock up. I tried restarting as the cylinder filled with gas every time. eventually it started....once it bent the rod into a pretzel and pulled the bottom out of the piston skirt, and toasted my brand new shortblock. good thing it was only cast parts, but you should see all the damage it did. ruined crank, 2 rods, all the rod bearings, and 1 piston was destroyed. ruined the block as well. put a piece right into the block and ruined my blueprinted oil pump.
Lol, you have your exhaust listed first, i was like wtf thats less than stock on the intake
The heads look pretty good, you may max out those 30 lb injectors though, if you haven't got them yet u should go with the 36 lb/hr.
detroitmuscle
Jul 31, 2015 04:21 AM
