what do you guys think of Scat?
Old Apr 15, 2007 | 11:45 PM
tagz's Avatar
I blew my motor last week and i'm in the process of building a new one. I plan on turboing it so i'm building for boost.
Havn't worked out all the details yet, but a friend told me SCAT made real good reliable parts. What do you guys think? Any one have experience with scat.
First time building an engine so i'm not sure about all the brands and **** like that. Its gunna be a all forged 355.. so far i got the following:
Scat Crank - forged 4-350-3480-5700-L
Pistons - JE -28 dish 532-170817
Piston rings - JE 532-J100F8-40305
Rods - SCAT forged 3ICR5700
From what i've been reading, -28 dished pistons should put me around 9.0:1 compression, depending on which heads i decide to go with.
Of course i'm gunna need other stuff like bearings, arp studs, oil pumps ect. Let me know what you think
Old Apr 15, 2007 | 11:46 PM
tagz's Avatar
Also going with splayed 4 bolt mains
Old Apr 16, 2007 | 12:26 AM
Try2CatchMike's Avatar
Scat is pretty disgusting
Old Apr 16, 2007 | 12:27 AM
theroad64's Avatar
lol...
Scat is a well known and time-tested name.
tagz's Avatar
good to hear
Old Apr 16, 2007 | 01:01 AM
slimdawson's Avatar
I agree. Some people just have no shame when it comes to getting their rocks off.
Old Apr 16, 2007 | 08:12 AM
sam pace's Avatar
Not sure on them yet.
I will find out once my car is running.
Old Apr 16, 2007 | 08:48 AM
SS MPSTR's Avatar
great parts for the price.
Old Apr 16, 2007 | 09:26 AM
Colin91Z's Avatar
I would say scat is fine. In fact last time I was at Ed Wrights shop getting a friends car tuned, I asked Ed what rotating assembly he had in his TA...he said crank and rods were SCAT...this is a 9 second car all motor mind you....
Old Apr 16, 2007 | 08:44 PM
Bersaglieri's Avatar
Buddies run all scat bottom ends in their small and big blocks, no problems yet, and that 454 in Matt's 69 Chevelle gets the ***** beat off it. I'll be going Scat on my rebuild soon.
-Dustin-
Old Apr 16, 2007 | 09:01 PM
reamo04's Avatar
javier here on cz28 has a 355 w/ scat stuff, i will be using scat also
my friend used scat in his motor, i trust scat
Old Apr 17, 2007 | 06:22 PM
RACEON's Avatar
Chekc the rings, and make sure they are good for blowers/boost. But also check if they are low tension or regular tension.
I am not an engine builder at all, but my engine has JE psitons and rings and they are low tension, and I use oil about a quart every thousand miles, which is more than I would like and the oil gets black real quick. Plugs are clean and I have no cats, but I should have gotten regular tension rings for oil consumption concerns. Just my 2cents
Old Apr 17, 2007 | 06:52 PM
jaguar5822's Avatar
There's plenty of videos about scat online, but you have to turn off your search filter for some reason or they probably won't show up.
Old Apr 17, 2007 | 08:04 PM
96capricemgr's Avatar
If buying a crank anyway I would consider a stroker.
Also when looking at all forged do yourself a favor and look at the Compstar SpeedPacks.
Compstar is Callies "budget" line, I have no problem with Scat and believe the parts you picked will hold but I also think for a similar price you could get the Compstar crank and rods and Mahle pistons(standard in this package) and have a better assembly for less money. Keep in mind the Speedpacks are COMPLETE balanced rotating assemblies bearings and all. You piece together parts and bring them to a local shop it will cost you at least $160 for balancing possibly much more.
drptop70ss
Mar 26, 2015 01:50 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Chevyguy358
Jan 28, 2015 08:04 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Red97LT1
Aug 7, 2002 05:45 PM
