What do you guys think?
Old Mar 25, 2004 | 04:14 PM
96ta(nick)'s Avatar
What should i go with for a new motor this fall?
355,383,396?
turbo,supercharged, or build it for nitrous?
Old Mar 25, 2004 | 04:25 PM
Daryn95Z's Avatar
Twin Turbo 396 w/ direct port nitrous!!!!
I guess it depends on what your budget is. Hope it's big.
Old Mar 25, 2004 | 04:27 PM
96ta(nick)'s Avatar
oh yeah and it has to be streetable but almost anything is "streetable" to me
Old Mar 25, 2004 | 05:01 PM
Daryn95Z's Avatar
Me too!
Whatever you get make sure you do lots of research and get what you want.
Old Mar 25, 2004 | 07:45 PM
My95Z's Avatar
go big... or go home
Old Mar 25, 2004 | 07:50 PM
Tony Danza's Avatar
keep track of your budget or you might not have a home to go back to!
plan it all out ahead of time. make sure its all that you want. there is a point of deminishing returns when having a new engine built concerning a money:HP ratio. That said, i recomend a 383 for no matter what you do - N/A or forced induction.
Old Mar 25, 2004 | 07:51 PM
formula king's Avatar
be a smart man and do a 355 turbo set up, and drop the comp. and boost the hell out of it......dont do the same thing everybody else does (heads cam stroke) be diffrent
Old Mar 25, 2004 | 11:14 PM
96ta(nick)'s Avatar
what will get me into the 9s range? with suspension and everything being overhauled as well..
When i first started modding my car i said i would stop at a mid 12...
Old Mar 25, 2004 | 11:26 PM
97WS6SCharged's Avatar
9's and streetable? Hmm... You're definately going to need a power adder of some sort. How much money are you willing to spend here?
Old Mar 25, 2004 | 11:38 PM
Daryn95Z's Avatar
If you want to go 9's and still be able to have it streetable, I would probably go for some type of turbo set-up.
Old Mar 26, 2004 | 09:49 PM
Tony Danza's Avatar
9's? wow! good luck trying to keep it a daily driver.......
Ok well what I can recomend is that you look up a member named SleeperZ28, look at his pictures in his links on his sig, here's one- http://www.augsburg.edu/ppages/~chial/index.htm
Although an extreme example, that should give you an idea of what a streetable 9 second car is (also the first that came to mind). prepare to have a damn hard time, along with a BIG chunk of money to say the least.
formula king-
hey theres nothing wrong with going with the tried and true routes. It's cheaper and it works!
Old Mar 26, 2004 | 09:54 PM
badazzcamaro97's Avatar
Id say go turbo
carguy0119
Apr 11, 2016 11:11 PM
blac94Z
29
Mar 25, 2015 04:21 PM
steve10358
Middle Atlantic
Mar 20, 2015 04:50 AM
mspennyhughes
Nov 28, 2014 03:22 PM
Red97LT1
Aug 7, 2002 05:45 PM
