What do you guys recommend to fix my loose 150k suspension?
Old Nov 29, 2003 | 09:37 PM
Kreinmc's Avatar
The car is all over the road! During normal driving the car grabs every little groove and really can't go straight. At wot the car will get real loose and wobbly and high speeds. Anyone have any experience with any of the front end rebuild kits that are offered? What specifically can cause the wobbliness at wot?
Old Nov 29, 2003 | 09:49 PM
InjectedSS's Avatar
Go get yourself some new outer tie-rods at autozone #ES3238 $33
Old Nov 29, 2003 | 10:17 PM
QCKZ28's Avatar
poly sway bar bushings would be helpful too.....
with new springs and shocks.....
jesse
Old Nov 29, 2003 | 10:41 PM
Compstall's Avatar
With the mileage you've got, I would make a project of it and change out ALL of the suspension bushings. Even rubber replacements would be night/day. Check your ball joints while you're there too.
Old Nov 29, 2003 | 10:57 PM
WOT's Avatar
WOT
repalcing all the bushings would be a good idea as is replacing tie rods and ball-joints that need it. I would definately get some new shocks while you are at it.
Old Nov 29, 2003 | 11:01 PM
Heatmaker's Avatar
Advanced Member
Defenantly replace the bushings. Mine are f34ked right now and it feels like ****. You can feel all kinds of sh*t in the road. Also I wouldn't stop myself from changing out the Wheel Bearings if I were you.
Old Nov 29, 2003 | 11:04 PM
Compstall's Avatar
Heatmaker, are you stalkin' me?
Old Nov 30, 2003 | 12:37 AM
neil350's Avatar
Kreinmc,
Did you ever get the vid again of your car with the CC306?
Neil
Fatdog2
Feb 13, 2015 08:19 PM
squarehead
Nov 21, 2014 08:02 PM
Fusion93Z
Sep 10, 2002 06:46 PM
slothgrant
Aug 22, 2002 03:01 PM
Red97LT1
Aug 7, 2002 05:45 PM
