Some quickies
Old Nov 29, 2003 | 02:01 PM
S8ER95Z's Avatar
Some quickies
Im out working in 30 something degree weather..laying in the mud out back. I think my engine is siezed and Im not having the best day... Heres a few no brainers .. I need some help..
What size it the Harmonic Balancer Bolt? Ive tried different sizes and Im so pissed right now my heads not clear enough to keep guessing.
How can I tell if its a timing gear? Froze Topend? Froze Bottom End? Anything in particular to try?
I just replaced the starter because the old one was fubar. Now I still cant start it. The motor turns (You can see the belt turn about an inch or 2. Then it stops.. and the power all drains inside the car (guages, lights, radio, etc all turn off)
Im going to try cranking it by hand..I have the plugs out just cant find a socket to fit the harmonic. Thanks in advance.
Old Nov 29, 2003 | 02:06 PM
FastWhiteTA's Avatar
Well from the fading gages statement I would suggest checking your battery (hopefully you did but it never hurts to sugget it). Your local AutoZone or auto store should be able to test it then charge it up. If your car doesn't have enough power to run the accessories it sure as heck won't have enough power to turn the motor over. Check that then get back to the other stuff. If the battery is dead enough, a jump won't even work all the time. I know this from personal experience while installing my LTs. I tried jump starting after the battery had been completely drained, and it wouldn't start. Took the battery and got it charged at Auto Zone and it started right up. Hopefully your problem is as simple as a completely dead battery.
Old Nov 29, 2003 | 02:08 PM
S8ER95Z's Avatar
Sadly its a brand new battery. Ignition Switch? This would be the 3rd one if it is.
Old Nov 29, 2003 | 02:10 PM
Hmmm ok.....
I had the ignition switch go out in my car, and when that went bad, my engine wouldn't even turn over.
Old Nov 29, 2003 | 02:26 PM
S8ER95Z's Avatar
Crank Bolt Size? Anyone know what socket fits it?
Old Nov 29, 2003 | 04:17 PM
$hawn's Avatar
5/8
Old Nov 30, 2003 | 12:08 AM
S8ER95Z's Avatar
Originally posted by $hawn
5/8
Thanks! I finally got motivated enough to try out a few..and got the right size. Not that it matters much. Engine is siezed.
Old Nov 30, 2003 | 12:18 AM
Spinner's Avatar
Could just be hydrolocked
Old Nov 30, 2003 | 12:24 AM
S8ER95Z's Avatar
Elaborate?? How could I "un hydrolock it"???
Old Nov 30, 2003 | 12:29 AM
Spinner's Avatar
WEll im not sure how long your engine has been sitting, but "hydrolock" refers to water, moisture, or (too much) fuel in the cylinder for the crank to turn over.
Old Nov 30, 2003 | 12:31 AM
jchevy's Avatar
If you have the plugs out that eliminates the hydo locked possibility. Good luck.
Old Nov 30, 2003 | 12:36 AM
PoorMan's Avatar
This may sound pretty dumb but did you try cranking it with all the plugs out. If the motor is froze it will not turn. If it is not, even a very weak battery can turn it over very freely. Plus, you can also easily hear a spun bearing doing it's thing this way also.
Jeff D.
Old Nov 30, 2003 | 12:37 AM
jchevy's Avatar
Re: Some quickies
[i]
Im going to try cranking it by hand..I have the plugs out just cant find a socket to fit the harmonic. Thanks in advance. [/B]
Old Nov 30, 2003 | 12:50 AM
S8ER95Z's Avatar
Guys..its already been attempted. Maybe i wanst clear enough. I hung my entire body weight from the ratchet and it didnt budge. All the plugs out. Ive changed headgaskets, etc.. not just the easy stuff. (even though headgaskets are easy) Regardless.. shes froze solid. It could have been a rod, or a piston ring, any number of things.. regardless... shes froze solid
1993Z28LT16SPD
Sep 18, 2012 05:14 PM
94Z28LS1toLT1
Apr 30, 2012 07:09 AM
sn8ke eatr
May 10, 2011 07:27 PM
Jason E
17
Jul 20, 2005 01:35 PM
