what do i need to rebuild the bottome end
Old Jul 15, 2009 | 09:15 AM
grimjeeper73's Avatar
Exclamation what do i need to rebuild the bottome end
i have a rod knocking / piston hitting the head. i know that i need main and rod bearings... but do i need a crank and does my cam bearings need replaced? i just need to know because i only have 300 dollars and i need to know whether i should fix it or save up and find a 500 beater to drive its my only car and i got 2 kids and a wife and unemployed i can do the job myself just need to know what price and what i need to fix it
thanks
Old Jul 15, 2009 | 04:36 PM
LSWHO's Avatar
You'll need a lot more than $300 will get you.
Old Jul 15, 2009 | 09:37 PM
97Whitez28's Avatar
If you have a rod knocking I don't see why you couldn't do it for about 500 or so, gasket kits are very expensive, but everything else is relatively inexpensive. OEM style rod and main bearings, rings, Gasket Kit, Oil and Filter, Coolant, is really all you would need, as long as you haven't drove it an messed up the crank journals or the rod journals they can be cleaned up to almost new condition usually with some emery cloth....
If you did somehow have piston to head contact, which would really only happen if you broke a timing chain then your probably better off buying a beater...
Old Jul 16, 2009 | 09:31 AM
Z28SORR's Avatar
I agree, you don't always have to spend a lot of money. Years ago many engines were rebuilt, while setting in front of appartment complexes, using modest hand tools.
Old Jul 16, 2009 | 01:41 PM
as soon as it stopped ticking and started knocking i stopped driving it so maybe i wont have to buy a crank
Victor Lamb
Aug 26, 2017 02:52 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Killer94z
Jan 13, 2015 12:06 PM
RichJ
Sep 26, 2002 09:43 AM
squirrels
Jul 13, 2002 01:58 AM
