what do i need to rebuild the bottome end
i have a rod knocking / piston hitting the head. i know that i need main and rod bearings... but do i need a crank and does my cam bearings need replaced? i just need to know because i only have 300 dollars and i need to know whether i should fix it or save up and find a 500 beater to drive its my only car and i got 2 kids and a wife and unemployed i can do the job myself just need to know what price and what i need to fix it
thanks
thanks
If you have a rod knocking I don't see why you couldn't do it for about 500 or so, gasket kits are very expensive, but everything else is relatively inexpensive. OEM style rod and main bearings, rings, Gasket Kit, Oil and Filter, Coolant, is really all you would need, as long as you haven't drove it an messed up the crank journals or the rod journals they can be cleaned up to almost new condition usually with some emery cloth....
If you did somehow have piston to head contact, which would really only happen if you broke a timing chain then your probably better off buying a beater...
Victor Lamb
Aug 26, 2017 02:52 PM
squirrels
Jul 13, 2002 01:58 AM
