What to do have Rust on Cylinder Walls
Old Dec 1, 2007 | 11:49 AM
B-Rad420's Avatar
I bought a used engine to swap into my firebird and before I got the heads on the cylinder walls got a chance to surface rust. What should I use to clean this up? Brad
Old Dec 1, 2007 | 12:06 PM
wrd1972's Avatar
wipe them with wd40
Old Dec 1, 2007 | 01:52 PM
B-Rad420's Avatar
Really, thats it? I dont need to get the rust off before I put the heads back on?
Old Dec 1, 2007 | 02:00 PM
Scrub the rust off with a coarse rag and oil.
Old Dec 1, 2007 | 02:20 PM
B-Rad420's Avatar
I tried that and couldnt get it off. What happens if I leave it on there? I am gonna go and try to scrub harder this time and see what happens.
Old Dec 1, 2007 | 02:22 PM
Kevin Blown 95 TA's Avatar
see if you can post a pic of it so we can tell you how bad it is (or isn't)
Old Dec 1, 2007 | 02:28 PM
B-Rad420's Avatar
I have a digicam but recently purchased a new PC and dont have the upload software It is only rust from sitting for 2 days when it rained. Was very humid afterwards and no it didnt get rained on, lol.
Old Dec 1, 2007 | 02:33 PM
It's probably inconsequential surface rust - unprotected iron will do that almost immediately in moist air. You have peaks and valleys in the cylinder hone pattern, and you probably can't scrub the rust out of the scratches without an abrasive - you should probably just clean them up with paper towles or lint free rags and wd or something similar and call it a day. I suppose you could use a scrub brush if you wanted. I had that happen to me a couple times in the past and nothing came of it.
Old Dec 1, 2007 | 04:12 PM
B-Rad420's Avatar
Thanks for the help man. I decided to put my timing chain cover on instead of mess with the cylinders but going back out in a sec to try the rough rag and wd 40. Brad
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
