Guideplates Install
Old Dec 1, 2007 | 04:45 PM
Stl94LT1's Avatar
Guideplates Install
I'm in the process of switching from self-aligning rockers to NSA's. Got any special tips to make sure the guideplates are aligned properly? Seems like their position can vary just a little.
Old Dec 1, 2007 | 08:34 PM
Romero155's Avatar
What kind of guidplates did you buy? I got the gmpp guidplates from the dealer and the align the rocker on the valve stem perfectly. I did try edelbrocks on before and the were misaligned, so it all depends on what plate you bought.
Old Dec 1, 2007 | 09:15 PM
Stl94LT1's Avatar
I got the TrickFlow guideplates. Looks like I got them aligned pretty well. Did a search, and someone said to push them down toward the header side and tighten.
Old Dec 1, 2007 | 09:38 PM
mzgp5x's Avatar
I cut them in half, lined up on the valves, then used duc tape to hold them. Remove and reweld. Or, you can buy linear adjustable types from Isky. Check their web site.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
Catmaigne
Dec 25, 2014 12:16 PM
